Tire Pressure Sensors? - JeepForum.com
post #1 of 6 Old 07-28-2009, 01:21 PM Thread Starter
IrDewey
2006 WK
I bought my 2006 Grand Cherokee Limited used, and as I've been using it, the "Spare Low Pressure" warning keeps showing up on the display. Upon inspection, I found that the spare tire appears to be a replacement, as it is smaller than the other 4 wheels. I assume this means that it doesn't have the pressure sensor in it. I've tried filling the tire, but it's been full all along.
Is there a way to turn the warning off?
IrDewey is offline
post #2 of 6 Old 07-28-2009, 11:24 PM
bmuhlbach
2005 WK
check out this web site -tire monitor system
http://www.wkjeeps.com/wk_tpms.htm
bmuhlbach is offline
post #3 of 6 Old 07-29-2009, 12:54 AM
merlinTec
merlinTec's Avatar
Hi
do a search on here been cover a lot. If you have no spare sensor (but you should have) you need to get one coded in or if you have a friend with the same wheels see if you can borrow one of his wheels for a day or two. What you then do is put one of yours in the spare and his on your jeep and if the car has been parked up for 4 hours or more you then drive it above 15 mph for 5 minutes to code his sensor. You then put his tire in the spare and put yours back on, park it up for another 4 hours then drive it again as above. You can then give him his wheel back and you will no longer need a spare with a sensor in it.
Best advice would be to have full size wheel with a sensor but but giving you options
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 6 Old 07-29-2009, 10:45 AM Thread Starter
IrDewey
2006 WK
I've read that article, and it doesn't help with a missing sensor. I did, however consider that the tire may not be trained to the system, but I wasn't able to find the magnet used to train it.
I may end up having to pay a dealer to fix it
IrDewey is offline
post #5 of 6 Old 07-29-2009, 12:06 PM
merlinTec
merlinTec's Avatar
Magnet to train them? lost me
post #6 of 6 Old 07-29-2009, 12:18 PM Thread Starter
IrDewey
2006 WK
Nevermind, I guess I read a different article. So, is there a way to just tell the system not to read from the spare tire? I'd like it if I didn't have to pay $50 for a new sensor.
IrDewey is offline
Tire Pressure Sensors from 2009 Jeep Wrangler X jdharri7 ZJ Grand Cherokee Forum 3 07-21-2009 04:28 PM
Tire Pressure Sensors spreadhead14 ZJ Grand Cherokee Forum 1 10-18-2005 07:29 PM
Train tire sensors Chris from WV ZJ Grand Cherokee Forum 1 09-09-2004 09:56 PM
Problem with internal tire pressure sensors caetravlr ZJ Grand Cherokee Forum 1 02-19-2004 08:03 AM
