Tire help please! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Tire help please!
Dual Color LED Light Bars White/AmberFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/Bla
Unread 07-18-2014, 10:12 AM   #1
VT-05WK
2005 WK
Tire help please!
I am buying duratracs this weekend and want to make sure everything fits. I have ome heavy springs with Bilstein shocks all around along with 1.5 inch spidertraxx and flattened pinch weld. Will I be okay running 255/75/17 or should I come down to 265/70/17?
I'm only asking because I don't want to order tires and then have them not fit or rub a whole bunch. Thanks for any help!
'05 WK 4.7L V8, OME HD w/ Bilsteins, 1.5" Spidertraxx, Flowmaster 40 series
Cobra CB, Dipped Badges
VT-05WK is offline   Reply With Quote
Unread 07-18-2014, 12:31 PM   #2
GC10LTD
2010 WK
You should be okay with the OME HD and Bilsteins. You don't have the Hemi and Omelet has HEMI and did the OME HD with 255/75/17 BFG's and they fit fine. You should be good. Just make sure that pinch weld is non-existent. Should be good to go. I didn't know you could get Duratracs in a 255/75. I only have found 265/70.
One last note, the only difference between the 255/75 and the 265/70 is that the 265 is going to be a little wider and shorter opposed to the 255/75 which is taller and narrower.
255/75/17 = 32.06"
265/70/17= 31.61"
If you have anymore question let me know.
2010 WK | 3.7L QT1 | K&N 77 Series Intake | ROLA Rack |....much more to come...
GC10LTD is offline   Reply With Quote
Unread 07-18-2014, 08:22 PM   #3
BoraBora
2006 WK
Ya they'll easily fit with plenty of room to spare.
2006 Black WK, Modified OME HD ~3.5'', Bilstein 5100's, 1.5" Wheel Spacers, Black JK Moabs, 285/70/R17 Duratracs, 7W Reverse LED's, tow hooks, 2 Hella 500ff's behind grill, Expanded sheet metal grill, ORT badge, Tail light guards, Firestik 3', Aux. input, Black housing headlights, Stingray roof basket, 2 Hella 500ffs on roof rack, 18% tint.
BoraBora is offline   Reply With Quote
