Ticking sound coming from behind the passenger dash. - JeepForum.com
post #1 of 3 Old 11-04-2011, 10:57 AM Thread Starter
debosmebo
(2005 Jeep Grand Cherokee Laredo)There has been a ticking sound coming from behind my passenger side dash for months now. It happens when I first start the engine and if I change my a/c on or change a/c levels. I also noticed my a/c only works on the highest level now. When it first started months ago, all levels worked fine. Not sure if its related, but my power seat no longer works either. I have tested all fuses to be good. Help please.
debosmebo is offline
post #2 of 3 Old 11-04-2011, 11:22 AM
clbailey
2005 WK
This same reason brought me to this site! Welcome, from a newish member to a newbie member!
Its the blow motor / door actuator for when you swap modes on the Climate Control.
Theres not much you can do besides remove the door IIRC, untill it craps out. My Jeep only does it when its really cold outside. It hasnt done it at all this year and weve had temps in the 30's. I did add the cabin air filter kit, dont know for sure but it seems to have helped the problem.
Like I said, not much you can do about it right now, dont worry about it unless you start losing air flow/temps arent what you want.
clbailey is offline
post #3 of 3 Old 11-04-2011, 11:26 PM
t3kmitch
2005 WK
Sounds more like the blower motor resistor.
http://www.jeepforum.com/forum/f67/h...sistor-926185/
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline
a/c , dash , noise , sound , ticking
Weird sound coming from pass side dash (possible heater core issue?) Got2HaveLights ZJ Grand Cherokee Forum 15 03-07-2013 10:51 PM
2007 GC CRD Ticking and knocking passenger side JeepCRD WK Grand Cherokee & XK Commander Forum 3 12-22-2008 05:19 PM
trivial ticking front passenger area haumana ZJ Grand Cherokee Forum 5 02-04-2008 01:30 PM
GC has a ticking sound(6 cyl) demtjcj ZJ Grand Cherokee Forum 6 10-29-2004 12:19 PM
Ticking Sound 98JEEP ZJ Grand Cherokee Forum 8 01-23-2004 08:37 AM
