Those With Torque, Dashboss, AutoEnginuity, Scanner, etc Come In - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Those With Torque, Dashboss, AutoEnginuity, Scanner, etc Come In
Grizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! BroughYukon Ultimate 35 axle kit for c/clip axles with Yukon Zip
Unread 09-04-2014, 07:20 PM   #1
ZWilson07
Cowboy
ZWilson07's Avatar
2008 WK
Im needing some readings from other people with WKs.
If you have some type of equipment that will allow you to get all four O2 sensor readings and you are willing to take a small reading for me, post up and I will PM you or post in the thread.
Thanks
2008 WK Overland 5.7 Hemi 4x4 QD2
Everything I need, plus a lot more I don't.
Black WK Club Member #154 || Hemi Club Member #89
ZWilson07 is offline   Reply With Quote Quick reply to this message
Unread 09-05-2014, 03:46 AM   #2
ggrassmid
I have DashBoss; but unfortunately I cannot help you; CRD here. DashBoss does seem to work well for me. Does everything I wanted plus has the 2 extra plugs for oil temp/pressure or other items should I choose in the future.
ggrassmid is offline   Reply With Quote Quick reply to this message
Unread 09-05-2014, 06:58 AM   #3
rulother
Grizzly
2008 WK
Have the paid version of Torque and love it, which do you need?
2008 WK 3.7L V6 Dark Khaki Club Member #75 "Grizzly"
2001 WJ 4.7 V8 (Sold)
1998 ZJ 5.2L V8 (Dead @ 300,000 Miles)
rulother is offline   Reply With Quote Quick reply to this message
Unread 09-05-2014, 10:17 AM   #4
luckyse7ens
2010 XK Commander
paid version of torque here
Black WK Club #152
luckyse7ens is offline   Reply With Quote Quick reply to this message
Unread 09-05-2014, 06:12 PM   #5
ZWilson07
Cowboy
ZWilson07's Avatar
2008 WK
Can you all put all 4 O2 sensors on your screen. When you are driving and vehicle warmed up, drive at a speed at least over 60 mph. Around 65 is fine and while cruising at that steady speed, go into a DFCO situation which really just consists of taking your foot completely off the gas and monitor what the readings do on the 4 sensors. They should drop some from going from a rich to lean state somewhat. Also see if it goes into open loop during this situation.
For some reason all 4 of mine jump to 0 and show open loop.
Thanks
Unread 09-05-2014, 08:13 PM   #6
Red_liner740
CRD here, but from my previous gas cars and monitoring O2 sensors, that seems right.
It goes into open loop as you have killed all injector cycling. No point in monitoring O2 sensors for fuel mixture when you go full lean.
Thanks
Red_liner740 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 03:47 AM   #7
ZWilson07
Cowboy
ZWilson07's Avatar
2008 WK
Well the reason is im having a problem with 013C code. Which is a slow response from rich to lean on back 2 sensor 2 during DFCO and 60 mph or higher. What isn't making sense to me it is only doing it during that DFCO event which in theory I was under the impression that when it does that and shows 0s on the gauge and is in open loop, the computer shouldnt be looking at any of that and throwing a code. It should go off pre-set data being in open loop.
So i think im having a PCM problem but I just wanted to see if others are seeing the same readings.
Unread 09-06-2014, 06:37 AM   #8
ZF1FR
2007 WK
DO you have acces to trans temp?
ZF1FR is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 05:16 PM   #9
ZWilson07
Cowboy
ZWilson07's Avatar
2008 WK
I don't know about him and the CRD but I THINK mine does for the hemi, I would have to go look for ya.
I am actually selling my dashboss since I got a really expensive tool. The dashboss is nice and convenient, I just don't need both.
Unread 09-08-2014, 05:56 PM   #10
ggrassmid
Yes I do.
The only things I wish I had that I does not monitor is Oil Temp and Oil Pressure.
It is supposed to keep track of DPF Regen mileage, but I could never get it to work. I have it set to watch the EGT and have an alarm on it that goes off when EGT is over 1000*F; which is usually only in regen mode. When this happens I keep driving until it is completed.
