For those with a front end "pop" - Page 5 - JeepForum.com
post #61 of 139 Old 09-05-2013, 07:04 PM
Atrain1066
2005 WK
I've got a 5.7, with a rough country 2" spacer lift. My clunking was so bad that when I would drive over rough patches of road it sounded like the whole front end of the Jeep was going to fall out. After reading this thread I ordered a set of external torx sockets on Amazon (http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1). This set has the E20, but it's 3/8 drive - not 1/2 inch, allowing you to use a smaller ratchet. With a 6 inch extension, I was able to make my adjustment without loosening the bolts holding the rack to it's frame. It's absolutely amazing that a quarter turn on that one little bolt can make all that noise go away. Now my Jeep is as quiet as it was prior to the lift. Could not be happier.
2005 Dark Khaki
5.7L HEMI
QDII
285/60R/18 Nitto Terra Grappler
Atrain1066 is offline
post #62 of 139 Old 09-05-2013, 09:30 PM
punisher65
punisher65's Avatar
2006 WK
I suspect that I need to do this, but it probably won't take care of all my clunks Thankfully those are only present when the suspension suddenly drops. I do have the acceleration clunk that people have mentioned. I'll try this on Saturday...sounds like an easy thing to do even if it doesn't fix everything!
2006 5.7 WK
OME HD, 265/70-17 Duratracs on Level 8 Strike 5, Aspen Creek Shackle Mounts,
Airaid CAI, Superchips Flashpaq, Gibson 3" catback, Steel Armadillo Engine Skid Plate
BT Catch Can, TB ground, Cree LED Reverse Lights, Interior LED upgrade
1993 4.0 ZJ
BB and 31" Bighorns SOLD :(
punisher65 is offline
post #63 of 139 Old 09-13-2013, 05:51 PM
jeepsrgood4u
2009 WK
I guess I'll try this on the weekend as well. I've got a bad clunk over bumps or uneven surfaces.. If that doesn't help anything I guess I'll put new sway bar bushings and end links on? Picked this up a few months ago not sure if it's lifted any or not, 21 1/4 hub to fender front and rear?
jeepsrgood4u is offline
post #64 of 139 Old 09-15-2013, 05:41 PM
jeepsrgood4u
2009 WK
Tweaked the rack and got 80 % of clunk and steering play out. Put some Moog sway bar bushings in after now she's golden! Thanks for the initial post and a heads up to everyone battling the issue...
post #65 of 139 Old 09-16-2013, 07:49 PM
RealDealWK
My clunk has to be this. I have no sway bars! Just got my e20 socket in
'05 WK - Hemi - Quadra-Drive II - RRO - BFG
NC State ENGINEERING
"What a wretched man I am. Who will deliver me from this body of death? Thanks be to God, through Jesus Christ our Lord." -Romans 7:24-25
RealDealWK is offline
post #66 of 139 Old 11-20-2013, 11:08 PM
ajxj9197
2009 WK
Managed to tighten it up without the E20 just only about an 1/8 turn but even that helped. Subscribed to this thread awhile back and finally got around to doing this. Thanks OP.
ajxj9197 is offline
post #67 of 139 Old 12-09-2013, 07:45 PM
lucifers_jeep
2007 XK Commander
I gotta do this, mine just started clunking after a week of hard use during deer hunting.
lucifers_jeep is offline
post #68 of 139 Old 12-14-2013, 05:54 PM
CrazyCanuck66
2008 WK
Hey
Originally Posted by trax95008 View Post
Tight fit? The bolt head is right in the open up front next to the swaybar bushing. Couldn't be any easier! Just get a socket on a breaker bar
Hey I was looking at ur pic that u posted. Is this where I'm suppose to tighten to get rid of the acceleration pop. I found this on my jeep just woundering why it's so different looking then the first 3 pics posted? And if it is which bolt in ur pic do I tighten?
CrazyCanuck66 is offline
post #69 of 139 Old 12-14-2013, 06:29 PM
trax95008
2006 XK Commander
The very first pic in the thread is the bolt on the rack that you adjust using a E20 socket. Only move it 1/8-1/4 turn. The pic I posted that your referring to, shows the bolt holding the rack to the frame. There are 2 bolts. If you back off those bolts a little, it allows the rack to move enough to get the E20 socket onto the rack to make your adjustment
trax95008 is offline
post #70 of 139 Old 01-10-2014, 02:55 PM
Saleen405
2006 WK
I don't have the "acceleration pop" you guys are talking about. It does clunk when I hit bumps tho. This morning the car was in park and I turned the wheel back and forth quickly and it was clunking. Could tightening this bolt fix that clunk? I already bought everything I need to replace the diff bushings because I didn't know if it was that that was clunking. I am just waiting for it to get a little warmer before I get into that. I think tightening this bolt is a little easier than doing the diff bushings.
Saleen405 is offline
post #71 of 139 Old 01-10-2014, 03:01 PM
trax95008
2006 XK Commander
My guess would be that your issue is ball joints or control arm bushings rather than the rack
post #72 of 139 Old 02-10-2014, 11:43 AM
Tamerin
2005 WK
Wait, that's the bolt we need to tighten? Is that the exact spot for the hemi?
Also, this also gets rid of play on the steering while driving right? Like my steering is pretty straight, just got an alignment, only above 60 is wobbles a little. And I randomly hear a pop or something when I accelerate, so this is the fix, yeah?
'05 Grand Cherokee, 3.7l V6, Sold
'05 Grand Cherokee, 5.7l V8, Current, Stock
Black WK Club #110
Tamerin is offline
post #73 of 139 Old 02-10-2014, 10:28 PM
trax95008
2006 XK Commander
Originally Posted by Tamerin
Wait, that's the bolt we need to tighten? Is that the exact spot for the hemi? Also, this also gets rid of play on the steering while driving right? Like my steering is pretty straight, just got an alignment, only above 60 is wobbles a little. And I randomly hear a pop or something when I accelerate, so this is the fix, yeah?
Yes, based on your symptoms, it sounds like you would benefit from this adjustment. However, the bolt I was talking about when you quoted me is to loosen the rack to help you gain access to the bolt head needing adjustment. Look back toward the beginning of this thread for pictures of the actual bolt head to adjust
post #74 of 139 Old 02-20-2014, 03:30 AM
james_2k
2003 WJ
has anyone got an idiots guide to this repair?
i cant find where the adjustment is to be made.. i cant even see the middle bit of the steering rack, seems to be pushed up against that frame bracket.
anyone got a nice step by step guide for the crd?
symptoms i have are.
slight knock going over small bumps. and if i go over several close small bumps at around 5 mph, get a quite awful clanking noise. dealer said they couldnt find anything in the suspension..
i dont have any clunks at all going from P N R or any combinations of them.
sometimes get a clunk when accelerating from 20 or so mph after coasting.
any ideas guys?
james_2k is offline
post #75 of 139 Old 02-20-2014, 08:22 AM
ajxj9197
2009 WK
Look at the 4th page. Shows a pic of the part. It's the star shaped bolt. E20 torx needed. It's on the driver side of the vehicle when you're looking up under it.
ajxj9197 is offline
Front end "clunk" on first brake application Hutchman ZJ Grand Cherokee Forum 19 04-03-2010 06:30 PM
Front Calipers "Teves" or "Akebono"? jimmy328 ZJ Grand Cherokee Forum 10 07-25-2009 09:48 PM
WJ Front axle/brakes "Binding" at slow speed jasn1981 ZJ Grand Cherokee Forum 0 06-29-2009 09:54 PM
Any suggestions on Front TB axle side hole "Ovaled out" fix ZJcrawler45 ZJ Grand Cherokee Forum 5 01-25-2009 05:18 AM
Black "EVAP" Canister Behind Front Bumper mr_user ZJ Grand Cherokee Forum 3 01-08-2006 01:50 PM
