For those with a front end "pop" - Page 3 - JeepForum.com
post #31 of 140 Old 10-29-2012, 07:10 PM
trax95008
2006 XK Commander
All you have to do is loosen the 2 bolts for the rack enough to slide it back a little. The socket will then fit
trax95008 is offline
post #32 of 140 Old 10-29-2012, 08:27 PM
SSF556
2008 WK
Originally Posted by trax95008
all you have to do is loosen the 2 bolts for the rack enough to slide it back a little. The socket will then fit
10-4
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #33 of 140 Old 11-03-2012, 07:37 AM
GCooperII
2005 WK
Awesome post. Thanks for sharing.
Been chasing this noise myself for a while. Thought it was bushings or a ball joint somewhere. Going to give this a shot today or tomorrow.
EDIT: And here is the Current link to the J E E P G a r a g e thread. The one above wasnt working for me. Just get rid of the extra spaces.
"http://www.J E E P G a r a g e.org/f...unk-47810.html"
2005 Grand Cherokee Limited
5.7-L V8 Hemi MDS 330 hp QuadraDrive II with ESLD
All the goods....Tow Pkg, SmartBeam, DVD, NAV, Rain Sense wipers
Finally installed: 18" JK Gladiator Wheels/Tires, RR2.5" Lift
SOLD: 1996 Grand Cherokee Limited Kevin's 2" BB 265/70R16Geolandar AT+II
GCooperII is offline
post #34 of 140 Old 11-04-2012, 07:07 PM
GCooperII
2005 WK
Problem Solved. No more pop on Acceleration.
post #35 of 140 Old 11-04-2012, 10:49 PM
trax95008
2006 XK Commander
It's odd that many of us are having this problem. I wonder if its a lack of proper adjustment when made, or just a poor choice in rack
post #36 of 140 Old 11-05-2012, 12:36 PM
JRLT
2010 WK
Great. Now I gotta buy two more Torx sockets, mine stops at 16.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #37 of 140 Old 11-05-2012, 12:36 PM
GCooperII
2005 WK
I dont know. As easy as the "bolt" on mine was to turn I wonder if after 117K it maybe has moved on its own cause it never did it until about 10k miles ago. Have had the lift on since about 37k
Then again, less than a 1/4 turn eliminated it alltogether any more than that and the wheel would not return to center on its own. Maybe its just the tolerances in there
post #38 of 140 Old 11-05-2012, 06:17 PM
ca07wk
2007 WK
I wish my pop was the bolt... I couldnt turn it either way... Might just be seized....
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #39 of 140 Old 11-05-2012, 07:45 PM
trax95008
2006 XK Commander
Mine took a bit of effort to break it loose. Just be sure you are using the correct socket
post #40 of 140 Old 11-05-2012, 07:49 PM
partlowr
2007 WK
Yep, I installed a lift two weeks ago and have that little pop once in a while now when starting from a dead stop as the weight transfers on acceleration. Good thread.
partlowr is offline
post #41 of 140 Old 11-05-2012, 07:51 PM
ca07wk
2007 WK
I got an E20 torx off ebay, maybe a little pb blaster will help
ca07wk is offline
post #42 of 140 Old 11-07-2012, 05:32 PM
GCoopII
Does anyone know what exactly is being done when that bolt is turned?? Is there a clutch pack or what?
GCoopII is offline
post #43 of 140 Old 11-07-2012, 07:27 PM
trax95008
2006 XK Commander
It's a yoke adjustment. I'm picturing a wedge of sort, taking up play in the moving parts. I'm sure it's a bit more technical than that.
post #44 of 140 Old 11-08-2012, 05:20 PM
GCoopII
Pinion lash maybe? Whatever the heck it is its hard to believe that a quarter turn or so makes such a huge difference. But it really does.
GCoopII is offline
post #45 of 140 Old 11-12-2012, 04:39 PM
Northwoods18
2005 WK
Thanks for posting this, it solved my problem. I lucked out and was able to get it to move with a standard socket and it didn't strip.
2005 WK Hemi -- Deep Beryl Green -- Volant CAI -- Taylor Shorties -- Throttle Body Ground -- Superchips Flashpaq 3875
-- OME HD -- Spidertrax Spacers -- 255/75/17 BFG M/Ts -- Stillen Stoppers
Northwoods18 is offline
Front end "clunk" on first brake application Hutchman ZJ Grand Cherokee Forum 19 04-03-2010 06:30 PM
Front Calipers "Teves" or "Akebono"? jimmy328 ZJ Grand Cherokee Forum 10 07-25-2009 09:48 PM
WJ Front axle/brakes "Binding" at slow speed jasn1981 ZJ Grand Cherokee Forum 0 06-29-2009 09:54 PM
Any suggestions on Front TB axle side hole "Ovaled out" fix ZJcrawler45 ZJ Grand Cherokee Forum 5 01-25-2009 05:18 AM
Black "EVAP" Canister Behind Front Bumper mr_user ZJ Grand Cherokee Forum 3 01-08-2006 01:50 PM
