for those 3.7s with the hypertech !! - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > for those 3.7s with the hypertech !!
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 05-19-2012, 10:39 AM   #46
JRLT
2010 WK
Got it and... it doesn't work just like you said.
Originally Posted by mattydipps View Post
just a little bit of advice, try and throw the tuner on as soon as you get it because i have the 52001 and more then likely, it will not work right away and you will have to send the problem to hypertech and it could take a few days...
Yeah it's real simple once you plug it into your computer after it doesnt work for your truck it does it automatically, just give hypertech a call the next business day to "confirm" they received your problem, I did and they pushed mine to the front of the list and I got it later that day
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/55/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline   Reply With Quote
Unread 05-19-2012, 11:43 AM   #47
mattydipps
2006 WK
exactly.. the 52001 isnt made for our WK 3.7s..... it can be updateable to work with our trucks.. the 52501 "should" work out of the box for our truck.. did you hook it up to the computer and send the error to hypertech?
[FONT="Comic Sans MS"][/FONT]matt-
[CENTER][B]06' WK, 3.7l, 2 inch Rough Country lift, HyperTech Max Energy 52001, Expanded Metal Grille Mod, Smittybilt rear recovery point, S4XC front recovery shackles with smittybilt 3/4 d-rings, Red Daystar d-ring isolators, Custom shorty antenna, cb radio, S4XC antenna mount, Firestik antenna & coax, 17 inch Moabs w/ 265/70/17 Falken Wild Peaks, Hella 500ff driving lights, Monroe Load Levelers 58643, Rola Roof Rack, Custom painted headlights with Red LEDs, Red LED back lit grille, AirRam power wire, Fastman Throttle Body, Airaid CAI, Flowmaster 40 series
[I]see how it was all made [COLOR="Red"][URL="http://www.jeepforum.com/forum/f67/mattydippss-build-thread-1336318/"]here[/URL][/COLOR] [/B][/CENTER]
[B][COLOR="Red"]RED WK CLUB #8[/COLOR][/B][/I]
mattydipps is offline   Reply With Quote
Unread 05-19-2012, 12:14 PM   #48
JRLT
2010 WK
I did and it wouldn't do any update. Do I have to write down an error code and email them?
Unread 05-19-2012, 05:13 PM   #49
mattydipps
2006 WK
Once you hook it up I your car and it says cal not found or cal not supported hook it up to your computer and it will automatically send the error to hypertech
Unread 05-19-2012, 07:15 PM   #50
Robb286
2006 WK
OR... Just plug it back up to your computer and mine just automatically updated itself without having hypertech send me an email with their update, click the "05-07 3.7", and it was ready to go!
Robb286 is offline   Reply With Quote
Unread 05-19-2012, 10:47 PM   #51
JRLT
2010 WK
Maybe you have the 52501 cause mine won't do anything like what you described, it's a 52001.
Unread 05-19-2012, 11:57 PM   #52
JRLT
2010 WK
Hey, anti-virus was blocking everything. Might be updated, gonna got check!
Unread 05-20-2012, 12:25 AM   #53
JRLT
2010 WK
It's working!
Unread 05-20-2012, 12:47 AM   #54
JRLT
2010 WK
And it works. Still gotta tweak it but the engine actually sounds different. Had too much to drink to get it out on the road but it seems the thing isn't afraid to go near yellow line on the tach when pushing on the throttle.
Now I need to buy a CAI and install the headers & Magnaflow. Saw there was a discontinued Mopar/Jeep CAI for the 3.7L's; kinda want to look for a NOS one of those.
Unread 05-21-2012, 11:49 PM   #55
JRLT
2010 WK
Got it installed.
Was out on the road taking the tuner through it's paces, saw a bull snake.
What can I say other than the throttle is way more responsive. For those of you that own a 3.7L, you know the difference between aggressive driving and not. Well, the tuner makes your non aggressive driving somewhat aggressive being that it seems that gas pedal is that much more responsive. Now I gotta learn how to drive less aggressive WITH the tuner cause it's just too easy to gun it. That and I gotta tweak the shift points cause I didn't and now the thing will go to yellow line in 3rd gear before it shifts, if you let it.
Unread 05-22-2012, 07:19 AM   #56
flexyxj
2009 XK Commander
I just ordered one this morning for my XK. I bought it for mostly correcting the speedo and the added snort is a bonus
flexyxj is offline   Reply With Quote
Unread 05-22-2012, 07:58 AM   #57
JRLT
2010 WK
Make sure you gather your info before hand, tire size in inches by the quarter inch & speed rating, so you're not doing what I did and running back in the house and looking up stats.
Unread 05-22-2012, 08:21 AM   #58
vwgtipowr
How much do these hypertech units cost?
vwgtipowr is offline   Reply With Quote
Unread 05-22-2012, 08:22 AM   #59
05WKinPA
2005 WK
379.00 new, you can find them used for less, just make sure the vehicle last used with it was returned to stock.
Rocky Road & OME MD hybrid lift / AEV Pintlers / 32" BFG Mud Terrains / Four X Doctor rear diff guard / JBA UCA's / 4XGuard Belly Skid / Stillen cross drilled rotors
05WKinPA is offline   Reply With Quote
Unread 06-02-2012, 11:43 AM   #60
WKFusion
2006 WK
I took my jeep on its first little road trip today with the hypertech and i was blown away by the mpgs! It was 68.1 miles on i80/ pa turnpike one way to the apple store in allentown pa.
22.9 was the highest i hit on the way down but i was going back and forth in the higher 19s/ 20s at 80/85 mph! A HUGE step up from a solid 13/14miles per gallon w/o the hypertech at the same speed. I wish i could make $hit this up. I think im in love!
what model # do you have?
Do you think I could get away with buying any model number HyperTech? or do I have to buy one that says "3.7l" ect.
2006 Cherokee Laredo 3.7L Current Mods:
Tinted windows/sun visor / HID KIT / Custom CAI / Pinch weld mod / 1.5'' Spacers / 265/70/17 -- Wrangler Authority / Hypertech / 2'' RC
WKFusion is offline   Reply With Quote
