Thinking about Adding Front skid Plate WK - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Thinking about Adding Front skid Plate WK
Win a free set of 35" or 37" tires from Zone OffZone Offroad - Jeep Forum Promotion50% Off Sale at KrawlOff-Road.com
Unread 05-18-2015, 05:23 PM   #1
KillaJeep4569
2006 WK
Hey guys, Im thinking about adding a Front skid plate, To protect some The engine bay area from the beach sand and Dunes. I have a few questions....
How much does one of these weigh?
Is it really going to pull down on the OME MD springs??
And who makes these skid plates for our truck?
KillaJeep4569 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 05:32 PM   #2
JakeWK
Reap the Jeep
JakeWK's Avatar
2005 WK
I'm sure there are a few companies out there selling front skids for our jeeps. A reliable one would be 4XGuard, which i'm sure you're familiar with.
From their site, a 4XG Front Skid weighs 36lbs. I think you can even get the steel one or the aluminum still..
It won't pull down on the front suspension as much as people think, because 36 lbs isn't a lot and it is closer to the springs themselves, instead of something like a steel bullbar or bumper. Even if you have the MD. It won't be too bad at all, i wouldn't be concerned over the added weight. If it's an issue, take an angle grinder and cut fore to aft strips out of it to reduce weight and a custom look.
here is the link to their site, of course do some looking around see if you can find other fabricators: http://4xguard.com/grand-cherokee-20...-guard-10.html
And let me know if you find one for cheaper so i can sell mine
05Hemi-ThuleAeroRails-4XG Diff/FrontSkid/Shackles-CAI-CatBack-SuperChips-BTcatchCan-31" 265/70 BFGs-GraphiteMoabs-2"RC lift-RearMonroeLL's-1.5"SpiderTrax-RR TailLampArmor-OptimaRedTop-HIDlows-Fogs
JakeWK is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 11:09 PM   #3
Chirpz
Chirpz's Avatar
2007 WK
I have the factory skid under the engine and the 4xGuard front skid in front of that..... no problem with the suspension. I don't have the weights...but they are heavy.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 06:47 AM   #4
KillaJeep4569
2006 WK
I'm gunna research some more I found a few places. But all were around the 275 range. Kinda think that is a tad high for some bent up aluminum. I'm kinda wonderin if iI could bend a sheet of aluminum myself in my shop as I am a tinknocker.
Unread 05-19-2015, 11:31 AM   #5
JakeWK
Reap the Jeep
JakeWK's Avatar
2005 WK
I barely have access to a decent welder, but have definitely considered making my own armor. I think it's easier than people realize, especially single-bend and cut sheets like front skids. Plus shape, design, and finish are so variable and can make for a very custom look. And all for a lot cheaper. I wish I would've. You should make your own! And post pictures 😁
Unread 05-23-2015, 05:30 PM   #6
SanDiegoDan
Junior Member
SanDiegoDan's Avatar
2007 WK
Is the 4xguard front skid (or any other) compatible with my tow hooks? thanks
"Cecilia" 2007 WK Limited Hemi 5.7 Quadra-Drive II black, 82k, lifted, 1.5" wheel spacers, BFG MTs on black Moabs, roof rack, front shackles, rear step/tow point, all chrome removed, mesh grill mod
SanDiegoDan is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 05:35 PM   #7
SanDiegoDan
Junior Member
2007 WK
I just emailed 4xguard with the above question... I'll share if I learn anything interesting
Unread 05-24-2015, 12:11 AM   #8
JakeWK
Reap the Jeep
JakeWK's Avatar
2005 WK
Unless I misread your question.. yes, the 4xg front skid plate won't affect what tow hooks you want to use at all. The bolts for the skid are nowhere near the bolts for the shackles.. any shackle that fits your jeep will fit with or without a front guard.
Unread 05-24-2015, 12:12 AM   #9
JakeWK
Reap the Jeep
JakeWK's Avatar
2005 WK
Add on- here is mine, I have the 4xg front guard with the 4xg shackles, but as you can see, the shackles you choose will be unaffected by the front skid plate.
Unread 05-24-2015, 06:52 AM   #10
SanDiegoDan
Junior Member
2007 WK
ahh yes I see how the guard mounts now... thanks !!
Unread 05-25-2015, 11:15 AM   #11
KillaJeep4569
2006 WK
Thanks guys prob gunna go 4x but it is a nice lil penny for it.
Unread 05-25-2015, 11:01 PM   #12
japeart
2007 WK
i have the aluminum steel armadillo front skid (they also do steel). its about half the weight of a steel one and covers from the front all the way to the back of the engine. quite happy with it. its about the same cost as the 4x guard but a better unit imo
http://thesteelarmadillo.com/index.p...&product_id=56
07 Grand Cherokee - 3.0L CRD - GDE Hot Tune - QDII - OME HD - 255/75/17 BFG MT
Black WK Club #156
japeart is offline   Reply With Quote Quick reply to this message
Unread 05-25-2015, 11:18 PM   #13
JakeWK
Reap the Jeep
JakeWK's Avatar
2005 WK
Does that plate cover the oil pan and transfer case as well? The two holes look like the drain holes in my stock oil pan/t case plate.. I've been looking for a one-piece armor plate that goes from the radiator to the oil pan.. If this is it, i will sell my 4XG immediately and get this one haha
Unread Yesterday, 09:17 AM   #14
ggrassmid
I also have TSA aluminum skid plate. It only covers from the lower rad support/mount to the back of the engine oil pan. They also sell a trans skid plate and a t-case skid plate for those that did not come equipped with the Jeep version. My CRD came with Jeep skid plates, so at this point I only wanted the added front coverage and will get the trans plate to cover that. Everything else is pretty well covered. I may opt for the 4xG belly plate instead of TSA trans plate though. I do like 4xG rock sliders with nerf bar.
Black 2008 Limited CRD
GDE EcoTune, EHM, 2014 Rubicon take-offs
JF Black WK Club #168
ggrassmid is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 10:01 AM   #15
japeart
2007 WK
Yeah it goes from the rad support to the cross member at the back of the engine. Doesnt cover the trans or tcase. Need other skids for those
Black WK Club #156
