Thermostat replacement direction - JeepForum.com
post #1 of 6 Old 11-01-2013, 02:18 AM Thread Starter
Wk1225
2008 WK
I took the thermostat off a 3.7 and forgot which way the thermostat is positions. Does the coil part go in or out of the engine? Because if it goes out it almost bottoms out on the housing
Wk1225 is offline
post #2 of 6 Old 11-01-2013, 06:31 AM
yzjwk
2005 WK
The spring goes into the engine and the little bypass should be pointing up . I believe that should always be the case on any engine .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 6 Old 11-01-2013, 09:48 AM
90grandoneer
90grandoneer's Avatar
2006 WK
Very true!!!
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is online now
post #4 of 6 Old 11-01-2013, 02:20 PM Thread Starter
Wk1225
2008 WK
Ok I had it right I just replaced the water pump and thermostat on my moms jeep and the next morning it started running like Crud and shut down we had it towed to the dealership and they think it's a burnt valve
Wk1225 is offline
post #5 of 6 Old 11-02-2013, 12:04 PM
jjarvis0007
2005 WK
Might have a air pocket? I had some bad ones in mine while replacing the entire coolant system. Once you figure out with the bleed valve its easy.
jjarvis0007 is offline
post #6 of 6 Old 11-02-2013, 01:38 PM
90grandoneer
2006 WK
Be wary of this. You just don't get a burned valve overnight. Bet it's something simple if it worked fine before you did the thermostat. DO NOT take them at their word. At least get a second and perhaps a third opinion before you do anything.
