Tech write ups/ DIY write ups - Page 4 - JeepForum.com
 4Likes
post #46 of 64 Old 11-04-2015, 08:02 AM
Nejeep
Rear Seat Headrest
Heres a link to the DIY for fixing the rear seat headrest problem. Headrest will not return to upright position after rear seat back has been lowered.
Thanks to those who posted.
http://www.jeepforum.com/forum/f67/h...oblem-1229975/
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #47 of 64 Old 11-22-2015, 09:23 AM
JakeWK
2005 WK
Also, here is the link to the rebuild kit i used. I found amazon was cheaper than rockauto.
http://www.amazon.com/s/ref=nb_sb_no...p%2FMitsubishi
05 WK HEMI
USN Jeep Club
CentralCaL 4X4
Colorado 4X4
JakeWK is offline
post #48 of 64 Old 11-22-2015, 09:27 AM
JakeWK
2005 WK
Here's the link to rebuilding the CV joint on the front driveshaft.
http://www.jeepforum.com/forum/f67/0...vibes-3504290/
05 WK HEMI
USN Jeep Club
CentralCaL 4X4
Colorado 4X4
JakeWK is offline
post #49 of 64 Old 01-09-2016, 10:25 PM
bmb063
2005 WK
Here's a write up on doing the front bearings:
http://www.jeepforum.com/forum/f67/r.../#post33528746
bmb063 is offline
post #50 of 64 Old 01-13-2016, 02:32 PM
Armor_LG
2010 WK
Here's my write up for an expanded sheet metal grill mod.
http://www.jeepforum.com/forum/f67/d...l#post33583858
Black WK #180
Armor_LG is offline
post #51 of 64 Old 01-28-2016, 08:34 PM
bmb063
2005 WK
Here is a how-to video I made for replacing the lift gate and glass strut supports:
I upgraded my 2005 WK Limited
bmb063 is offline
post #52 of 64 Old 07-04-2016, 07:30 PM
Nejeep
window regulator calibration
Here is a write-up on how to calibrate the door window auto-up feature, if you are having problems with the window regulator not working correctly, ie it goes up but then rolls partially back down. I found some other short procedures which might work, but this one is more detailed and did work correctly for me.
1. Drive the glass into the full-up position by pulling up on the window switch to its second detent (manual mode) and holding the switch until the glass is fully closed.
2. Drive the glass to the full-down position by pushing down on (depress) the window switch until the window glass is fully open. Do not release the window switch. Continue to hold the window switch down for 30 seconds after the window glass is fully open. Confirm that the express-up module has been de-activated by attempting an express-up cycle. The window should not operate in express mode. It should stop moving when you release the window switch. If it still does work in express mode, repeat step 2 holding the switch down for 40 seconds.
3. Drive the glass into the full-up position by pulling up on the window switch to its second detent (manual mode) and holding up on the switch for at least one (1) full second after the window glass is fully closed.
4. Check the operation of the express-up feature.
Edit: Do this window-up calibration with the engine running so the system voltage is "normal" 14.0 to 14.5 (not the 12.3 volts with the engine off).
Nejeep is offline
post #53 of 64 Old 08-07-2016, 12:09 PM
radioouman
Here is the procedure to change the CV joint on the front drive shaft.
https://youtu.be/Wm4MvCh3VwQ
2007 Jeep Wrangler Unlimited Rubicon
2005 Jeep Grand Cherokee Limited Hemi
radioouman is offline
post #54 of 64 Old 09-05-2016, 12:15 PM
Chirpz
Chirpz's Avatar
2007 WK
Replace CRD alternator step by step
My alternator went out for the 2nd time the other day. 1st time I had it replaced under warranty. This time it became a DIY project. Click either of the links below if you wish to see my step by step guide.
http://www.chirpz.com/jeeps/alternator/Alternator.html
or
http://www.chirpz.com/jeeps/Alternator.pdf
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #55 of 64 Old 09-06-2016, 07:35 AM
08zombie
2008 WK
How-To install Morimoto Wrangler LED Fog Lights on a WK:
http://www.jeepforum.com/forum/f67/h...ts-wk-3851865/
Check My Threads For These Builds:
WK LED Headlight Quad Retrofit
WK Morimoto LED Foglights
08zombie is offline
post #56 of 64 Old 12-13-2016, 10:23 PM
Mike07crd
2007 WK
Can we get something on this list as to what should be replaced when doing a 2"+ lift?
Sent from my SM-T550 using Tapatalk
Mike07crd is offline
post #57 of 64 Old 12-14-2016, 12:39 AM
Clarkyau
2006 WK
Only what comes in the kit (spacers/springs &/or shocks)
What I would do.
With a spacer lift I would replace the rear shocks because of the extended travel created.
With a spring lift both the front & rear shocks to suit the new travel.
You will hear a lot of talk about upper control arms but really they aren't needed for 2". 60,000miles on a 2" lift with original upper control arms, that's 140,000 miles all up.
If you need upper ball joints then sure get them, I'm still waiting for mine to fail
http://plus.google.com/u/0/+DownunderJeep/posts/p/pub
Clarkyau is offline
post #58 of 64 Old 04-14-2017, 11:05 PM
Chirpz
Chirpz's Avatar
2007 WK
4xGuard Differential Guard step by step
Thinking about a differential guard? Here is how the 4xGuard works and looks.
http://www.chirpz.com/jeeps/diffguard.pdf
or for web format use the following
http://www.chirpz.com/jeeps/diffguard/Diff-Guard.html
Chirpz
Chirpz is offline
post #59 of 64 Old 05-15-2017, 10:49 PM
Chirpz
Chirpz's Avatar
2007 WK
4xGuard Matrix System installation Step by Step
I bit the bullet and bought a full 4xGuard Matrix system. It is pretty easy to install IF you have the OEM tow hooks on your Jeep. If you do not have the tow hooks, it is a little more difficult. Since I DID have the tow hooks, my step by step guide does not deal with the other senario.
Click either of these link to view my guide.
http://www.chirpz.com/jeeps/Matrix.pdf
http://www.chirpz.com/jeeps/matrix/Matrix.html
Chirpz
Chirpz is offline
post #60 of 64 Old 05-19-2017, 10:49 AM
Chirpz
Chirpz's Avatar
2007 WK
Chirpz - Step by Step Guides
I decided to put all of my DIY guides in one place so that they will be easier for folks to find when needed. You can not find and download any or all of my guides at the following link...
http://www.chipmunksoftware.com/ds708/?page_id=76
or at:
https://goo.gl/bKVLR0
CavallinoRed and underscore like this.
Chirpz
Chirpz is offline
