Tech write ups/ DIY write ups - Page 2 - JeepForum.com
 1Likes
post #16 of 57 Old 12-24-2013, 04:53 PM
Chirpz
Chirpz's Avatar
2007 WK
How to change a glow plug
Here is my write up on how to change a glow plug.
http://www.chirpz.com/jeeps/glowplugs/index.html
or you can download the pdf file at...
http://www.chirpz.com/swirl/glow_plug.pdf
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #17 of 57 Old 12-24-2013, 05:05 PM
Chirpz
Chirpz's Avatar
2007 WK
4xGuard Side Rails
Here is a link to my write up on 4xGuard Siderails
http://www.chirpz.com/jeeps/4xrails/4xrails.html
or download the pdf at
http://www.chirpz.com/swirl/4xrails.pdf
Chirpz
Chirpz is offline
post #18 of 57 Old 12-24-2013, 05:08 PM
Chirpz
Chirpz's Avatar
2007 WK
DPF Delete
Here is my guide to DPF Delete
http://www.chirpz.com/swirl/DPF_Delete.pdf
Chirpz
Chirpz is offline
post #19 of 57 Old 12-24-2013, 05:11 PM
Chirpz
Chirpz's Avatar
2007 WK
4xGuard Belly Guard
Here is my write up on the Belly Guard
http://www.chirpz.com/jeeps/4xbelly/4xbelly.html
or download pdf at
http://www.chirpz.com/swirl/4xGuard_Belly.pdf
Chirpz
Chirpz is offline
post #20 of 57 Old 12-24-2013, 05:15 PM
Chirpz
Chirpz's Avatar
2007 WK
4xGuard Front Guard
Here is my write up on the front guard
http://www.chirpz.com/jeeps/4xfront/4xfront.html
http://www.chirpz.com/swirl/4xfront.pdf
Chirpz
Chirpz is offline
post #21 of 57 Old 12-24-2013, 06:07 PM
Chirpz
Chirpz's Avatar
2007 WK
4xGuard Rear Guard
Here is my write up for the Rear Guard
http://www.chirpz.com/jeeps/4xrear/4xrear.html
or download the pdf here...
http://www.chirpz.com/swirl/4xrear.pdf
Chirpz
Chirpz is offline
post #22 of 57 Old 12-24-2013, 06:09 PM
Chirpz
Chirpz's Avatar
2007 WK
Elephant Hose Mod
Here is my write up on the EHM
http://www.chirpz.com/swirl/Elephant_Hose.pdf
Chirpz
Chirpz is offline
post #23 of 57 Old 12-24-2013, 06:15 PM
Chirpz
Chirpz's Avatar
2007 WK
Swirl Motor Replacement
Here is my write up for Swirl Motor Replacement
http://www.chirpz.com/swirl/Swirlmotor.pdf
Note: This job is no longer necessary due to the discovery of the "resistor fix" and of the availability of the "GDE Tune."
Chirpz
Chirpz is offline
post #24 of 57 Old 02-10-2014, 12:48 AM
Chirpz
Chirpz's Avatar
2007 WK
Turbo Actuator Repair
Here it is, my step by step guide for Turbo Actuator Replacement.
You can view it online at this link...
http://www.chirpz.com/jeeps/ta/TurboActuator.html
or you can download the PDF file at this link
http://www.chirpz.com/jeeps/TurboActuator.pdf
Chirpz
Chirpz is offline
post #25 of 57 Old 02-13-2014, 09:21 AM
BonesWK
2006 WK
Great videos on changing out Door Handle's. Save you big $$$ instead of going to the dealer. Just buy the replacement part from ebay etc. and follow the videos.
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #26 of 57 Old 02-18-2014, 06:14 PM
Chirpz
Chirpz's Avatar
2007 WK
N23 Recall Temporary Fix.... very easy
Troy123 posted a good write regarding how to fix the N23 Recall without buying a Flashpac.
It seems to work. Give it a try if you lost your 4Lo. This is probably not a permanent fix, just a way to clear the code and get your 4Lo back for a while... we'll see.
Here is a link to his writeup.
http://www.jeepforum.com/forum/f67/n.../#post20463273
Chirpz
Chirpz is offline
post #27 of 57 Old 02-23-2014, 01:25 PM
DarthJeep
2005 WK
My DIY, Rear trunk mod for 265-70-17 tires. Updated.
http://www.jeepforum.com/forum/f67/t...-tire-2143905/
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #28 of 57 Old 02-25-2014, 01:33 PM
jtodaro
2014 JK Wrangler
Taylor Shorty Plug Wires - 2005 5.7 Hemi
2005 Hemi Taylor Shorty Plug Wire Swap (I didn't write it, but wanted to reference it & the correct part numbers for the 3 color choices of wires)
Part # based off other posts of people that have done this. This REALLY cleans up the rats nest of wires on the 05 Hemi.
Taylor Cable 82641 - (Blue) ThunderVolt 8.2mm Spark Plug Wire Sets
Taylor Cable 82241 - (Red) ThunderVolt 8.2mm Spark Plug Wire Sets
Taylor Cable 82041 - (Black) ThunderVolt 8.2mm Spark Plug Wire Sets
2014 JKU Sport Anvil
jtodaro is online now
post #29 of 57 Old 02-25-2014, 11:39 PM
Chirpz
Chirpz's Avatar
2007 WK
CRD Fuel Filter Replacement
I replaced my fuel filter for the 2nd time yesterday and decided to post a step by step procedure.
You can view my procedure as a web page here:
http://www.chirpz.com/jeeps/fuelfilter/Fuel_Filter.html
or you can download the PDF file here:
http://www.chirpz.com/jeeps/Fuel_Filter.pdf
Chirpz
Chirpz is offline
post #30 of 57 Old 02-28-2014, 08:07 AM
IIMacGyverII
2007 WK
Complete turbo replacement
Anyone have write up to replace the entire turbo?
With the direction of Chirpz, I found this post from Tuco. It's brief but better than nothing.
Originally Posted by Tuco View Post
The Turbo is Out! I figured I wouldnt sleep tonight with the turbo half way removed. Removing the Turbo takes about 4 hours for the first time. Take your time because you dont want to strip or break bolts. I will use the newest looking bolts and high temp copper antisieze compound when installing. Will be sure to torque to minimum allowed value.
It wouldnt hurt to spray some penetrating oil. I didnt on these bolts. You want a high quality impact torx bits E10 and E12 with 3/8 drive. You need an assortment of ratchets, and extensions. Make sure the torx and ratchet extensions are perfectly parallel to the bolt and that the torx is well seated. Tap lightly with a wrench or small hammer. Do not use cheap sockets! They are really tight and some needed a 1/2 inch drive for more leverage. First remove the egr flex elbow with 4 E10 bolts. The two lower ones are tight so be prepared for a battle. Loosen all 4 then remove all 4. Now loosen the 8 E12 bolts then remove them. The last two bolts require Torx 45 male socket and are easy to access. Loosen them all the way but dont remove them, instead let them come up with the turbo. There is a small metal gasket cliped to the turbo it might fall off so put a rag or something back there to catch it.
Lesson learned: While the swirl motor can be removed with Turbo in place, I recommend doing the job proper and remove the turbo so that the swirl is really easy to get to. Yes, it will add about 12 hours to the job, but damaging the delicate manifold swirl linkage can cost a lot more in parts and labor. I lucked out because I have new manifolds ready to install. I think I will put the new turbo on too.
I will do a formal write up later with all the nice pictures.
Thanks to Chripz and Tuco!
2007 WK CRD Limited Fully Loaded. GDE Hot Tune, SWK Member 115
1996 ZJ Limited -RIP
N23 Recall Victim
IIMacGyverII is offline
