TCM P0750...codes and more codes and the one speed tranny - JeepForum.com
post #1 of 4 Old 11-01-2008, 07:02 PM Thread Starter
Mattt0305
2005 WK
Well I posted a week ago and got some great replies but most wanted to know the in depth codes over the generic P0700. Ive just parked the thing and finally got it to a dealer to pull the real codes. It's locked in third which i assume is limp mode, so here it goes. P0750 P0841 P0870 P0935. I can look them up and most seem to deal with pressure but the one is solenoid A malfunction. Anyone ever change one of these solenoid packs? Is it as easy as it looks, pull the pan and remove the filter and valve body and its bolted to the VB. Is this actually the problem. Oh well, any advice is welcomed, Cheers all.
Mattt0305 is offline
post #2 of 4 Old 11-01-2008, 07:19 PM
robpp
You say you can look them up? Do you have the Service Manual? If not, I have the 005WK and can share the details. Let me know and I'll post up the manual pages for each code.
I am only reading and providing my opinion:
Since all of them are hydraulic fluid related, have you had the fluid level checked. Some models there is NO dipstick. And there is a process to check it based on the temperature of the fluid. I would get a power flush on the transmission. And maybe a pan filter too. My guess is either not enough fluid or contaminated fluid.
You dont list engine/transmission, that could help others with similar provide feedback too.
Good Luck,
Rob
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #3 of 4 Old 11-01-2008, 07:37 PM Thread Starter
Mattt0305
2005 WK
Ah yes, sorry, its a 2005 GC(of course) 4x4, 4.7l with a 545rfe, the one with the dipstick. Fluid is fine, first thing I checked. I should give the whole history too. This happened once or twice a year ago and took it to a dealer and they said it was the pressure line sensor, they took it out cleaned it and it was fine till a week ago. But this is somewhat different. All i had to do before was turn the car off and start it back up and it was fine. Now.... It's just third gear all the time. I have a new sensor but I work for the railroad and havent had time to crawl under and replace it. The worry is that darn solenoid A malfunction one. Ahhh. I still love her though. Thanks Rob I'll take any help or advice.
post #4 of 4 Old 11-01-2008, 09:50 PM
robpp
Yeah that sheds a bit more light.
I agree, change the sensor and see what happens.
Good Luck
robpp is offline
Fault Codes, DTC Diagnostic Trouble codes ETC. ef1992 ZJ Grand Cherokee Forum 4 07-16-2009 01:59 PM
2K WJ not running right with fuel inj codes & No ASD relay output voltage codes. HELP hillside250 ZJ Grand Cherokee Forum 0 04-06-2009 02:17 AM
6 Codes... New to codes and Tranny issues jakewalczak ZJ Grand Cherokee Forum 6 02-06-2008 07:32 PM
Tranny codes SX400 ZJ Grand Cherokee Forum 5 01-23-2007 06:02 PM
Tranny error codes CJjacquez ZJ Grand Cherokee Forum 3 10-20-2006 03:51 PM
