Tail Light Question - JeepForum.com
post #1 of 8 Old 07-27-2012, 09:58 PM Thread Starter
zeds_dead
2005 WK
Tail Light Question
So my right tail light wont light when I turn on my headlights but it will illuminate when i press on the brake or hit the turn signal. I have LED Tails so I tried to plug in the stock one but same thing happens. Any suggestions?
Everyday, something new you want to do. Disease of Jeeps.
zeds_dead is offline
post #2 of 8 Old 07-27-2012, 10:23 PM
Sohcvtec1995
Get a meter and make sure your getting signal. If not start working backwards.
Sohcvtec1995 is offline
post #3 of 8 Old 07-27-2012, 10:32 PM
trax95008
2006 XK Commander
Keep in mind it's a dual filament bulb. The running light is separate than the brake/turn. Start by cleaning the contacts in the socket, then use a meter to check for voltage, check fuses. There's also the chance that both the bulbs are bad. Try swapping from the other side
trax95008 is offline
post #4 of 8 Old 07-28-2012, 10:02 AM
JBert
2005 WK
For LED setup?
-Justin-
1988 YJ, 2005 WK
JBert is offline
post #5 of 8 Old 07-28-2012, 02:55 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
Is there anything else that doesn't work?
The right tail light is on IPM fuse 10, but I'd expect the right front parking lamp to be out as well if the fuse is the problem.
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #6 of 8 Old 07-28-2012, 03:11 PM
trax95008
2006 XK Commander
Originally Posted by JBert
For LED setup?
The socket has 3 wires. A ground, a +12v running, and a +12v brake. It doesn't matter if the bulb is incandescent or LED. One incoming wire tells one filament to light, and another wire tells the other, more brighter filament to light. The same two wires tell the LED to come on at a certain brightness, and the other wire tells the LED to get brighter. The principals are the same and require the same troubleshooting steps regardless of the bulb technology
post #7 of 8 Old 07-28-2012, 03:44 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
^ +1
w1pf is offline
post #8 of 8 Old 07-28-2012, 04:16 PM
JBert
2005 WK
Thanks for the explanation! I didn't realize that it worked like that.
-Justin-
1988 YJ, 2005 WK
JBert is offline
