T-Case Skid Help - JeepForum.com
post #1 of 8 Old 04-05-2014, 01:05 PM Thread Starter
sebastien
2006 WK
T-Case Skid Help
I need to know what size the bolt is that holds the T-Case Skid to the crossmember. Does anybody know??
http://www.blacksheep4x4s.org/
sebastien is offline
post #2 of 8 Old 04-05-2014, 02:55 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I wanna say it's a 14 or 15mm fine thread.
Edit:
^^^ That might be irrelevant.
If you're needing the length/thread pitch I don't know.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 8 Old 04-06-2014, 07:25 PM Thread Starter
sebastien
2006 WK
Anybody..? Looking for pitch, can I find these at dealership?
post #4 of 8 Old 04-06-2014, 08:43 PM
JeepN4KC
JeepN4KC's Avatar
Might try a local hardware store and tell them you need to try a handful to see which ones you need.
Sounds a bit goofy but crawl under your rig in the parking lot to test fit.
Then you'll know and you can purchase them.
~Mike~
WK
XJ
JeepN4KC is offline
post #5 of 8 Old 04-06-2014, 10:56 PM
caddydaddy
2007 WK
If it helps, the front skid bolts are M8 x 1.25 course thread and 30mm in length. Might be a place to start!
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
199,000+ miles!
caddydaddy is offline
post #6 of 8 Old 04-07-2014, 03:41 PM Thread Starter
sebastien
2006 WK
Mods can delete this if they like... Found what I needed, picked up a random bolt in the store and it worked.
post #7 of 8 Old 04-10-2014, 08:40 PM
Chirpz
Chirpz's Avatar
2007 WK
Go figure. I never have that kind of luck.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #8 of 8 Old 04-13-2014, 02:16 PM
Red_liner740
So whats the thread pitch and size so other people dont have to go through the trouble.
A good investment is in TPI guages. They arent expensive and they will tell you what threads per inch bolt you have in your hand so you can order the proper ones. They also come in tap and die sets.
Red_liner740 is offline
