Switch Panel -- Dubtype1 Style - JeepForum.com
post #1 of 10 Old 05-12-2011, 06:54 PM Thread Starter
Dubtype1
2006 XK Commander
I had to fab up a quick switch panel for my roof/driving/fog lights before ECCC. This is what I came up with.........................
Grabbed some textured 1/8" plastic and cut it the shape of the cubby pocket thing (Technical term). Then I used a heat gun to form it like the front of the cubby. I drilled 4 holes for the mounting screws and test fitted it. Then, i made some back brackets out of some metal I had found. I bent the ends so it grabs the inner lip of the hole. Once I got it to fit the best I can get it, I cut out the switch area and cleaned it up. I first sprayed the panel a light grey I had laying around, but it did'nt match the dash. So, I re-sprayed it black (Ishould of used matte black but all I had was gloss). I installed the switches, wired them up and installed the panel to the dash......I still have to finish wireing the whole set-up but it's done for today...Here's the pics, enjoy.
If and when I decide to re-do the panle, I will pay more attention to detail and use smaller screws and different switches. All-In-All, I think it came out good.
I don't need no stinkin' signature!
Dubtype1 is offline
post #2 of 10 Old 05-12-2011, 07:23 PM
Budasac
2005 WK
Looks great. I woulda gone w/ flat black though.
I look at every fab as a learning experience, then try to make the next one a little better. Nice touch with the heat gun.
Budasac is online now
post #3 of 10 Old 05-12-2011, 09:53 PM Thread Starter
Dubtype1
2006 XK Commander
Thanks, I just used what I had laying around. Therefor, the gloss is what I used, but I can always re-spray it later. It actually doesn't look that shiny in person, must be the camera.
Dubtype1 is offline
post #4 of 10 Old 05-13-2011, 05:17 AM
Budasac
2005 WK
no, the gloss looks fine. I'm just ****in' w/ ya.
As far as the screws go. I would have gone with a smaller head too. I wouldn't re-do the whole thing. But, If it really bugs you, instead try swapping out the screws for silver allen head screws to match the vent panel above it. That might look cool.
post #5 of 10 Old 05-13-2011, 07:02 AM Thread Starter
Dubtype1
2006 XK Commander
LOL, I kinda figured you were.......
That's a good idea with the screws, I'll look into that. Thanks.
Dubtype1 is offline
post #6 of 10 Old 05-13-2011, 07:33 AM
criket
2005 WK
dang this looks awesome. I just wish my cb wasn't in that spot. I may have to move it.
2005 | WK | Khaki | 3.7 | QT1 | OME HD Front Struts | Rusty's 2" lift in Rear w/ Monroe load levelers (F150 version) | 265/70 Nitto Terra Grapplers | 17" Moabs | 1.5" wheel spacers | Pinch weld mod Rear fender trim mod | 4xG Matrix w/ reciever hitch | 4xG Belly guard | SOLID Diff cover | Cobra CB radio | 4xG antenna mount | Rola roof
criket is offline
post #7 of 10 Old 05-13-2011, 08:05 AM
Devilsmed98
Looks great, almost factory if you put some fancy switches in there.
~Black WK Club Member #9~
2011 WKII Overland
2007 WK Limited[/COLOR]
1995 YJ Rio Grande
Devilsmed98 is offline
post #8 of 10 Old 05-13-2011, 09:17 AM
CoreyZ
Looks good.. but you spent all that time to make it work, then didnt get the switches to line up? Redo them man... and it will be great!
'12 JK COD:MW3 Edition
'10 WK, Black(sold)
Colorado Jeep Club member #217
CoreyZ is offline
post #9 of 10 Old 05-13-2011, 10:20 AM
BonesWK
2006 WK
sir did you swap out your ac vents?? or am I lost
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #10 of 10 Old 05-13-2011, 10:53 AM
Budasac
2005 WK
I have my CB in that spot too. I put the switches in the cubby below the A/C controls. You can fit at least three in there nicely.
Front drive shaft. Replace cv style with a u-joint style? bjl95mustang ZJ Grand Cherokee Forum 6 04-17-2011 09:04 AM
Panel Lights Flash When Headlight Switch Is In Auto bandanaboyz ZJ Grand Cherokee Forum 9 01-27-2010 09:18 AM
95 ZJ,replacement front axle is a cv style,but I have U-joint style-interchangleable? boxster ZJ Grand Cherokee Forum 16 04-18-2009 11:54 AM
Installed roof lights and made a switch panel for my lights aaron7 ZJ Grand Cherokee Forum 11 04-15-2009 12:32 PM
Trying to install light switch panel, hidden screw?? JacobDRoberts ZJ Grand Cherokee Forum 0 08-17-2008 07:56 PM
