Swirl question I haven't seen asked yet - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Swirl question I haven't seen asked yet
Unread 06-18-2013, 11:10 PM   #1
WKNick
2008 WK
I tried search but never saw this particular question addressed ....
Once a swirl motor failure occurs and is repaired at the dealership, is the fix permanent or is it possible you could have another failure again down the road?
I ask because the one we just picked up came with the service records and a previous owner had the misfortune of having to deal with the failure.
Thanks in advance!
WKNick is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 01:45 AM   #2
terrasmak
2007 WK
Resistor mod or GDE tune. Never worry about the swirl motor again
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 06:45 AM   #3
BAH101
2008 WK
Thanks in advance!
Unless you have the new black intake tube seal and have done an Elephant Hose Mod, I would say no, there is no permanent fix. Even with these mods, the swirl motor is just an electric servo motor that could fail at some time for any number of reasons. To eliminate any problems, you should check out the threads on the swirl motor resistor mod, which will trick the ECU to believe the swirl motor is working, or, as the previous poster implied, get a GDE tune as it disables the swirl motor and prevents getting the CEL. You also gain from increased MPG and power.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 09:12 AM   #4
suzieque
2008 WK
Thanks in advance!
its a valid question. I've read posts from owners that have done the costly repair twice, mostly on the UK forums where owners of Chrysler 300c also have the issue. By the way, the same problem also occurs on Mercedes equipped vehicles with the 3.0L CRD engine.
Certainly if you continue with the older style air intake tube and orange air intake tube seal, you risk oil dripping on the swirl motor and having it fail again, however, I have read of multiple swirl motor failures even with the new air intake tube and black air intake tube seal.
I have no concrete evidence, but I am speculating that the swirl flaps inside the intake manifold are so gummed up with EGR soot and oil that eventually the swirl flaps seize and cause the swirl motor to fail.
Some dealers clean or even replace the intake manifold when the swirl motor is replaced. You will have less chance of a subsequent failure if this is done at the same time as the swirl motor. In my opinion, if the dealer cleans or even replaces the intake manifold when the swirl motor is replaced AND you install the "elephant hose mod", you may never have a swirl motor failure.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 07:53 PM   #5
WKNick
2008 WK
Thanks everyone, I kind of suspected that it was not permanent, after all what incentive is there for them to fix something that generates so much business right?
So it looks like mod #1 will be the GDE tune... Darn...
Now I just need to decide Eco tune or Hot tune. Maybe I'll just get both and have options
Unread 06-19-2013, 08:04 PM   #6
Chirpz
2007 WK
When I took mine to the dealer they had no idea what they were doing. I decided to take it home and fix it myself after they spent almost 3 hours figuring out that the SM was dead. I already knew that and told them what I suspected but it took 3 hours for them to convince themselves. Then their estimate was $1200 to $3500 depending on whether or not they broke the linkage.
I fixed it myself with some encouragement from Tuco.... then several months later I heard about the GDE Tune and dove right in. Now I have a new SM that does nothing...but I'm happy.
I use ECO tune with dpf delete. Love it.
[B]Chirpz[/B]
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote Quick reply to this message
