Swirl Motor Plug - JeepForum.com
post #1 of 6 Old 06-14-2013, 04:39 AM Thread Starter
jamie1131
2003 WJ
Swirl Motor Plug
Does anyone know the part number/manufacturer of the swirl motor connector?
jamie1131 is offline
post #2 of 6 Old 06-14-2013, 09:49 PM
Tango.
2008 WK
Are you asking so you can delete it with a resistor? If so then you can use "cool tape" to wrap it and it works good, or 1 guy on here made some delete plugs.
Tango. is offline
post #3 of 6 Old 06-15-2013, 01:17 AM Thread Starter
jamie1131
2003 WJ
I want to make an actual plug in connector. I can order the parts at work if i know the manufacturer and part number.
post #4 of 6 Old 06-15-2013, 08:31 PM
TimM
2007 WK
Jamie, if you haven't already done it, you might want to read this thread: http://www.jeepforum.com/forum/f67/c...8/index19.html
Shibby Engineering makes the resistor plug which I ordered. It is a well made item and cost about $25 from memory. Seems that it took quite a bit of doing to track down the right plug etc. It is possible to achieve the same thing with a resistor and some heat resistant tape but if you want a more professional, and relatively inexpensive, fix you might be better off just ordering from Kurt at Shibby Eng. Good service and he delivers overseas.
There was a guy in the UK that ordered them in bulk (Probably from Shibby) and sold them in your neck of the woods - think I saw this on a UK Chrysler 300 forum). Good luck.
TimM is offline
post #5 of 6 Old 06-15-2013, 10:12 PM
Tango.
2008 WK
Taquache was who I was thinking of.
#35-38 shipped international
Email Kurt @ shibbyutman@hotmail.com to place your order
Tango. is offline
post #6 of 6 Old 06-16-2013, 11:44 AM Thread Starter
jamie1131
2003 WJ
The only guy I can find selling these in England is charging 39, thats about $55!
I'd like to find the part number for the plug, especially as i can order them via work!
