Sway Bar Links for Lifted WK - Page 3 - JeepForum.com
post #31 of 50 Old 06-21-2013, 06:50 PM
WieSeL
Originally Posted by EtherealPonx View Post
It would be when lifted, my angles look the same when on the ground ...
Maybe just didn't notice...
WieSeL is offline
post #32 of 50 Old 06-21-2013, 09:36 PM Thread Starter
CCUMP
Is the factory trac bar not adjustable?
CCUMP is offline
post #33 of 50 Old 06-21-2013, 09:47 PM
WieSeL
No it's a solid piece of steel. No adjustment, what you see is what you get. When you lift it becomes to short to keep the rear diff centered and will default the diff to one side. You adjust the new track bar to be longer than stock
WieSeL is offline
post #34 of 50 Old 06-22-2013, 12:03 AM Thread Starter
CCUMP
Then ill be ordering a rustys trac bar on the morning cause I need to get my jeep aligned b4 my tires start to wear wierd.... I'm pretty sure my lift put me over the 23" rule with the MLL, blistens and RC spacers
CCUMP is offline
post #35 of 50 Old 06-22-2013, 08:54 AM
BoraBora
2015 JK Wrangler
Have any pictures? I'll be putting the same lift and strut/shock pair in within the month. This thread has taught me a lot, so I need an adjustable trac bar?
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #36 of 50 Old 06-22-2013, 10:37 AM Thread Starter
CCUMP
CCUMP is offline
post #37 of 50 Old 06-22-2013, 10:38 AM Thread Starter
CCUMP
CCUMP is offline
post #38 of 50 Old 06-22-2013, 10:52 AM
EtherealPonx
Here is what the angles look like on the ground, similar
On the subject of track bar, you don't 'need' an adjustable one, its better to have one though on a lifted GC. Anything that returns components back to stock position is beneficial, or compensate for the changes. I will also be getting the rusty's adjustable Track Bar
In my case however the priority is the UCA ..
EtherealPonx is offline
post #39 of 50 Old 06-22-2013, 11:43 AM Thread Starter
CCUMP
It won't let me post pictures on here until I hit 25 posts
CCUMP is offline
post #40 of 50 Old 06-22-2013, 12:25 PM
BoraBora
2015 JK Wrangler
I see them....? Beautiful stance though, makes me even more excited to get it all installed
BoraBora is offline
post #41 of 50 Old 06-22-2013, 12:49 PM
EtherealPonx
Forgot my truck hasn't been pictured yet in the garage here, been spending too much time on the 'other' forum here is what the final product looks like.
Here is the beast:
Now I am in between the RRO and JBA UCA, just emailed JBA to ask a few questions about the length of the UCA to make sure the strut clearance issue is resolved...
post #42 of 50 Old 06-22-2013, 11:18 PM Thread Starter
CCUMP
Off topic, but I love that grey color on ur WK
CCUMP is offline
post #43 of 50 Old 06-28-2013, 03:05 PM
esfitz79
Junior Member
esfitz79's Avatar
What length are you guys doing on the BWoody's. I have the OME HD on my rig, and the bushings on the stock links are dead. I know the OME HD adds about 3" of lift, and i know the links dont have to get that much longer. I have heard about 1/2" up front and an inch in the rear.
1986 CJ7 Laredo
2007 WK Grand Cherokee - Rocky Mountain
esfitz79 is offline
post #44 of 50 Old 06-28-2013, 06:22 PM
ca07wk
2007 WK
I have the RC and I am running stock length upfront and +1" in the rear. I think 1/2" upfront and 1 1/2-2" in the rear will work well for you
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #45 of 50 Old 12-07-2015, 08:20 PM
05BlackWK
2005 WK
I have ome HD coils with Bilstein 1500s all around. What length bwoodys sway bar should I order?
05BlackWK is offline
swaybar links
