Suspension work on superlifted wk - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Suspension work on superlifted wk
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 07-19-2015, 08:29 AM   #1
budro574
2005 WK
New MOOG upper control arms, MOOG inner and outer tie rods from Kolak (thanks btw), lower balljoint on the driver side, and driver hub. I'm doing all of this to get rid of an outside tire wear on the front tires. Everything is brand new suspension up front, so I am hoping that problem is solved. I was doing some reading on the forum and it said that some people let the suspension sit on the wheels before tightening the lower control arms. Does this sound right? Alignment is getting done tomorrow, I don't want them to do the alignment without tightening the suspension up correctly. Thanks!
budro574 is online now   Reply With Quote Quick reply to this message
Unread 07-19-2015, 07:57 PM   #2
caulk04
2008 WK
Waiting until it's on the wheels is good for the bushings. You crank them down at a neutral position rather than extended. That said, I always forget...
Sounds to me like you just needed an alignment or maybe rotate your tires, but new parts won't hurt anything.
08 5.7 Limited WK - Basic stuff...
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2015, 03:12 PM   #3
budro574
2005 WK
I had the shop doing the alignment loosen the upper and lower control arm bolts before doing the alignment. Im hoping premature tire wear is over.
