Suspension Lift for '06 Jeep Grand Cherokee (WK) - JeepForum.com
post #1 of 16 Old 09-24-2012, 09:09 PM Thread Starter
dubyak
I've got a 2006 WJ Limited with the HEMI engine. I'm wanting to do a suspension lift. Previously, I had owned a WJ and went with a BDS 4" suspension lift...loved it, but the death wobble wasn't desired. I'm told you don't get the death wobble with the WK. Is there anything undesireable that comes from lifting a WK? Anything with the electronics or the tire pressure display...stuff like that?
What suspension lift do you recommend? It seems most people like the OME 2" lift. Is that the best?
A sister company of BDS, Zone makes a 4" kit that comes with a heck of a lot more than the OME kit.
OME suspension lift: http://4xguard.com/affiliated-produc...kit-wk-xk.html
Zone suspension lift: http://zoneoffroad.com/product?ki=365&gr=-1
Which, btw...what's the difference between the Med Springs OME 2990 and
HD Springs OME 2991 with the OME kit?
Does OME make a 4" lift? I haven't found one. Is there any other suspension lift that anyone would recommend? With my WJ I had to have a dual stabilizer once I lifted it. Is this needed for the WK?
dubyak is offline
post #2 of 16 Old 09-24-2012, 09:18 PM
S1L3NT_WH33L3R
2005 WK
Not trying to be rude, but all these questions have been addressed several times. You can search the forum for all these answers.
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline
post #3 of 16 Old 09-24-2012, 09:32 PM
Kolak
Vendor
Kolak's Avatar
There's sort of a legendary thread about problems with the Zone kit on another forum. If you want to go with a 4" lift, go with Superlift.
The OME kit is half the price of the Superlift, gives you 3" of lift, and allows for 32" tires. Would that be sufficient?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #4 of 16 Old 09-24-2012, 09:45 PM
jjt250
2007 WK
If you're going over 4 inches of lift and can afford it, go with the Superlift. Never heard anyone complain about the OME. The difference between the Medium duty and the Heavy duty is different spring rates. Most people with V8s or CRDs seem to go with the HD. OME doesn't make a 4 inch lift.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #5 of 16 Old 09-25-2012, 08:12 AM
eprovenzano
2005 WK
I just installed an OME HD on my WK. I've gained 3 inches in the front and 2.5 in the rear. The ride is much better then stock. I thought the HD would be harsh, but no, its firm, controlled and very comfortable.
Is there a reason why your set on 4 inches of lift? Give the OME another look, I'll bet it will suite your needs.
2012 Grand Cherokee Limited Wk2 (Momma's)
2005 Grand Cherokee Limited, WK, 4.7 V8 currently rolling on Cooper Discovery 265 70 17's, with 1.25" spacers.,installed an OME HD lift sourced through Kolak.
1996 XJ 6 inch lift on 33's (Son's)
eprovenzano is offline
post #6 of 16 Old 09-26-2012, 10:51 AM Thread Starter
dubyak
I'm leaning towards the OME HD (I have a HEMI). I guess my concern was whether I'd be able to fit 32" tires without doing additional mods. Can this be achieved or is the pinch weld mod and other stuff required? I was looking into 4" lift because I had the BDS 4" lift on my WJ and with that I was able to add 32" tires without any rub. OME HD seems to be the way to go...I'm just hoping to get 32" tires without the rub.
dubyak is offline
post #7 of 16 Old 09-26-2012, 10:56 AM Thread Starter
dubyak
With the OME HD is there an issue with ESP compatibility? If so, is there something that can be done?
dubyak is offline
post #8 of 16 Old 09-26-2012, 02:23 PM
eprovenzano
2005 WK
I have had no issues with the ESP. To clear 32's the pinch weld mod will need to be done, but it's not difficult to do.
post #9 of 16 Old 09-26-2012, 03:25 PM
trax95008
2006 XK Commander
I have a 3" OME HD lift with 32" tires and have NO rubbing
trax95008 is offline
post #10 of 16 Old 09-26-2012, 05:34 PM
Theogriff15
2006 WK
I have the days tar 2" lift with bilateins all around which probably yeilds like 2.25" total. I have 33's and no rubbing. Granted I've done the pinch weld mod and have the spidertrax 1.5" spacers. If u don't have the spacers your Deffinetly going to have to trim the upper control arm bolt but you shouldn't have any problems with the 32's with an one hd
2006 - 3.7L, Superlift, 265 Guard Dogs, 30" LED Bar, Bilsteins, Spidertraxx, Solid, Hypertech, Rola, Rear Led, Led Tails, S4xC Skids
Theogriff15 is offline
post #11 of 16 Old 09-27-2012, 04:15 PM Thread Starter
dubyak
Does OME make a 3" kit? I thought it was just a 2".
dubyak is offline
post #12 of 16 Old 09-27-2012, 04:37 PM
S1L3NT_WH33L3R
2005 WK
Yes I have the 3”
post #13 of 16 Old 09-27-2012, 08:15 PM
skrach77
2005 WK
The OME kit is listed as both, yet is the same kit (I believe). The average gain from it on a vehicle that does not have lots of extra weight from things like armor, is 3". Some claim a little more than that, but I think after a few thousand miles of break in for the new springs, you end up settled somewhere just at 3".
skrach77 is offline
post #14 of 16 Old 10-02-2012, 11:32 AM Thread Starter
dubyak
OME Kit
Next up...tire size confused the hell out of me. If I go with the OME HD suspension lift, would I be able to fit a size 32" tire?
Someone on Craigslist is selling a set of five wheels and tires off their Rubicon Jeep. With a lift, would these wheels/tires fit? They are listed as: 255/75/17.
I have the Limited model with Moduflex chrome wheels currently.
I believe they will fit, but want to confirm. Thanks for the help.
dubyak is offline
post #15 of 16 Old 10-02-2012, 03:01 PM
Kolak
Vendor
Kolak's Avatar
A 32" tire is perfect with the OME lift, and the 255 width should not require wheel spacers.
or
Kolak is online now
Want to lift 2005 jeep grand Cherokee? ajbullock WK Grand Cherokee & XK Commander Forum 1 07-12-2011 01:53 PM
how can I lift my Grand Cherokee besides a suspension lift? 95jeepL ZJ Grand Cherokee Forum 18 09-15-2010 02:13 PM
Jeep Grand Cherokee Lift Question Mda1234 ZJ Grand Cherokee Forum 30 08-21-2008 11:00 PM
98 Jeep Grand Cherokee 4x4 lift options jwbehm ZJ Grand Cherokee Forum 2 10-09-2007 04:39 PM
How big of tires can I do ona 2.5in suspension lift 1994 grand cherokee 87blkcherokee ZJ Grand Cherokee Forum 1 01-04-2007 09:32 AM
