Superchips Advanced Transmission Tuning - Page 2 - JeepForum.com
post #16 of 16 Old 06-29-2013, 01:02 PM
90grandoneer
90grandoneer's Avatar
2006 WK
You shouldn't have any problems then. None of this is rocket science, but graphing takes a little time and helps with understanding how/when things are going to happen and, especially, how the downshifts are related to the upshifts.
I think, knowing what I know now, I'd probably lower the TM in 20% intervals instead of 10% intervals, especially the ones at the higher speeds and higher gears. The lower gears and speeds will "feel" the lower TM a lot quicker than the others. You'll see when you give it a go.
Here's the info. on the Sonnax Line Pressure Booster:
http://www.sonnax.com/line-pressure-booster-kits
http://www.sonnax.com/system/announc...57-LB1_LB2.pdf
And, here's where I bought mine: http://www.transmissionpartsusa.com/...-044957lb2.htm
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, TruFlow Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, Transgo Shift Kit, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
Superchips 3875 Advanced Trans Option mdsbigpapa WK Grand Cherokee & XK Commander Forum 26 12-20-2010 12:17 PM
Superchips Advanced Trans Tuning now available Superchips WK Grand Cherokee & XK Commander Forum 13 05-26-2010 09:35 PM
advanced bulbs for LOW, HI, & FOG straty1987 ZJ Grand Cherokee Forum 8 10-15-2009 07:14 PM
Rustys 4.5 Advanced Kit asu4x4TA ZJ Grand Cherokee Forum 5 05-29-2008 07:02 PM
Rustys advanced kit for WJ? vwmaniacx ZJ Grand Cherokee Forum 27 05-18-2008 11:13 AM
