Superchips Advanced Transmission Tuning - JeepForum.com
post #1 of 16 Old 09-17-2010, 10:41 AM Thread Starter
etotino
2005 WK
Hello to all. I just bought the advanced transmission tuning feature for my Superchips Flashpaq. I have a 2005 WK Limited Hemi and am running 265/65/17 tires. I would appreciate any suggestions for shift schedules, etc., from anyone who has used the advanced transmission tuning feature. Thanks.
etotino is offline
post #2 of 16 Old 09-17-2010, 02:10 PM
maxst2
2006 WK
I just used superchips selection rather than custom setup... it does a good job too for me at least.
2006 65th Anni. Grand Cherokee 4x4 in black w/ 4.7L V8
maxst2 is offline
post #3 of 16 Old 09-17-2010, 03:46 PM
jeepfan30
2014 JK Wrangler
It took me months to figure out the shift schedules and get them set the way I like. I will post my settings if you are interested, I have 33 tires though, so my shifting preference might be different than yours in some gears.
3" EVO Enforcer, Fox 2.0 Shocks, 4.56 w/Truetracs, Coast F&R DS, 35" Toyo M/T, Warn Zeon 10-S
jeepfan30 is offline
post #4 of 16 Old 09-17-2010, 05:26 PM
jager00
2005 WK
great im got one on the way please post them!
2007 JK Sahara- trying to figure this one out
2005 WK 9" lift on 37's with all the goodies- regretfully sold :(
jager00 is offline
post #5 of 16 Old 09-17-2010, 07:23 PM
Acidcold
2005 WK
I am interested!
Acidcold is offline
post #6 of 16 Old 09-17-2010, 07:54 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
ME TOO!!! I have just been using the SC setup. It is ok, but it could definitely be better. I have been too busy to play with it. Please post it up!
Omelet is offline
post #7 of 16 Old 09-17-2010, 08:00 PM
jager00
2005 WK
i just noticed he has the hemi so it prob wont be the same for us 4.7 boys will it?
jager00 is offline
post #8 of 16 Old 09-17-2010, 08:41 PM
BLEEDNJEEP
I wanted to try this schedule-
Index of /SuperChips
For Commander 2006. I haven't had any time...
BLEEDNJEEP is offline
post #9 of 16 Old 09-18-2010, 11:39 AM Thread Starter
etotino
2005 WK
JeepFan30, I'm interested in your shift schedules. Please post them. Thanks!
etotino is offline
post #10 of 16 Old 09-18-2010, 09:25 PM
jeepfan30
2014 JK Wrangler
Here is what I am currently using. This by no means is a professional setup, just my tinkering for the way I like MY jeep to shift. If you damage your jeep in any way, do not blame me lol!
post #11 of 16 Old 09-20-2010, 05:01 AM
DanaT
A 4th gear upshift point at 149mph? I doubt it will make it to 149mph.
-Dana
DanaT is offline
post #12 of 16 Old 09-20-2010, 08:22 AM
jeepfan30
2014 JK Wrangler
I didn't even notice that, I used a template from one of the beta testers and adjusted only my gears that needed it.
post #13 of 16 Old 06-26-2013, 09:55 PM
KunningSTUNT
2005 WK
Hate to revive a dead thread but did you guys end up working out a good shift schedule? That link above doesnt work anymore. :/ Or f
can you point me in the direction of where I can find some more info on custom shift schedules, much appreciated
05' WK Grand Cherokee Laredo 4.7L QTII
- modified OME HD
- custom snorkel / air intake
- lukey exhaust
- superchips
KunningSTUNT is offline
post #14 of 16 Old 06-28-2013, 08:04 PM
90grandoneer
90grandoneer's Avatar
2006 WK
A couple things first.....I didn't find the setup to be too difficult but, even today after using it almost exclusively since 5/21/10, I still make minor adjustments from time to time. I got mine "real close" after about the 1st attempt. Also know that everyone's preferences are different and, depending on how your WK is modded, your setting may need to be significantly different from others. On mine with the 5.7 and MDS, I set mine to maximize the "on" time of the MDS. On your 4.7, you won't need to worry about this. I also added the Sonnax Line Pressure Booster to the transmission, which helps by increasing the clutch clamping pressure.
I'll tell you how I went about setting things up, FWIW:
1. First I drove it around for a few days, paying particular attention to the things I didn't like with regard to the up/down shift schedules and the torque management...shift firmness. I made notes and wrote down (and dated) up/down shift schedules on all of these items. Torque management is a complete, ongoing experiment though. I started by lowering (%age wise) all of them in 10% increments. This is where some tinkering comes into play. Even today I could lower a couple of them by about 10%, or so.
2. Like at least one other member, I got a couple "beta" schedules off the internet which, in my case, were in graph format. They really weren't too much help as far as shift schedules go, but did give me some hints on how things should be set up.
3. Using the "beta" graphs as a model, I then graphed the up/down shift schedules, using each of the speeds listed on the tuner.....first for the stock setup and then the way I thought (using my notes) I wanted mine to be. Graphing the stock setup (currently showing on the SC Tuner) further enlightened me and confirmed some of the things I noticed on the beta schedules......the most noteable ones being that the downshifts should not overlap the upshifts at any point on the graph and the closer the up/down graph lines are to each other, the more sensitive the downshifts are to the slightest throttle increase. The farther away they are from each other will require somewhat more throttle to force a down shift.
4. Once you load the initial settings you "dream up", you'll get an idea where you stand. Then it's a matter of periodic tinkering and "fine tuning" to zero it in the way you want it. I did do a few more graphs, (mostly to get my light throttle down shifts to the sensitivity that I wanted) but most of it was slightly adjusting my initial settings.....a little at a time. I'd say that I drove it for maybe a week or two between adjustments, again making notes on what I wanted to change. I'd also date the changes, so I knew what was what.
5. My current light throttle up shift schedules are are all above 2000 RPM (most ~2200-2300 RPM), all the light throttle down shifts require very little application of throttle (absolutely no lugging the engine) to force a downshift, and my 4-5 light throttle upshift is set for ~69 mph. Since my FRI Sidewinder cam works better at a higher RPM, almost all my highway driving is in 4th gear....~62-67 mph, or ~2100-2300 RPM. This also maximizes my MDS "on" time. My usual highway fuel economy is ~20-24 mpg (mostly 21-23 mpg) depending on the never-ending wind. Just got back from a 185 mile trip today and mileage was 22.4, figured with a calculator.....185 miles, 8.25 gallons of non ethanol 91 octane fuel.
Hope this gives you some pointers, and if you have any other questions, I'll try to help any way I can.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is online now
post #15 of 16 Old 06-29-2013, 05:53 AM
KunningSTUNT
2005 WK
Wow cheers for taking the time to write that up, very informative. I have a copy of a custom shift schedule from a 4.7l same as mine running the same size tyres as me so I was going to use those parameters initially then tweak them accordingly. I'm normally pretty good with getting my head around operating electronic devices so I shouldn't have any issue using the tuner and ive also read about the safe guard that prevents you from crossing the shift points over. The thing that really interests me is the torque management im hanging to give that a crack. What is this line pressure booster you mentioned?
- modified OME HD
- lukey exhaust
- superchips
Superchips 3875 Advanced Trans Option mdsbigpapa WK Grand Cherokee & XK Commander Forum 26 12-20-2010 01:17 PM
Superchips Advanced Trans Tuning now available Superchips WK Grand Cherokee & XK Commander Forum 13 05-26-2010 10:35 PM
advanced bulbs for LOW, HI, & FOG straty1987 ZJ Grand Cherokee Forum 8 10-15-2009 08:14 PM
Rustys 4.5 Advanced Kit asu4x4TA ZJ Grand Cherokee Forum 5 05-29-2008 08:02 PM
Rustys advanced kit for WJ? vwmaniacx ZJ Grand Cherokee Forum 27 05-18-2008 12:13 PM
