sunroof rear drain tube replace - JeepForum.com
post #1 of 2 Old 01-21-2012, 11:32 AM Thread Starter
selkplitt
1989 FSJ Wagoneer
Was curious if anyone has experience in replacing the rear passenger side sunroof drain. I have removed the headliner and blown air in but can still tell there is an obstruction although some air goes through. I closed it back up hoping it was enough but it wasn't. I bought a new drain tube for the $5.00. My question is, when the tube goes down the c pillar, can i just pull it out or do I need to remove the lower trim to get to pieces that hold it in place. Trying to figure this out before I start tearing it apart again.
Thanks for any help.
07 commander sport
selkplitt is offline
post #2 of 2 Old 09-29-2013, 07:40 PM
mdamen
I just went through this on my 05 GC. You can't get to the tube once it goes into the C pillar. I took out the rear seat and all the trim and you can't see anything.
Looking under the car, I can only see a small drain hole that is filled with foam. After the drain tube is installed, they shoot foam into the cavity for sound deadening. It tends to dislodge the end of the drain tube and plug it with foam. I do not know of a way to get to the end of the drain tube at the bottom of the C pillar.
mdamen is offline
how do i unclog a sunroof drain in an 05 GC? orangez WK Grand Cherokee & XK Commander Forum 16 10-14-2014 06:39 PM
Where is the sunroof drain tube will_b ZJ Grand Cherokee Forum 2 06-15-2007 07:53 PM
Clogged AC drain tube? lma1973 ZJ Grand Cherokee Forum 14 11-26-2006 05:32 PM
AC Drain Tube tek2977 ZJ Grand Cherokee Forum 13 05-11-2006 02:07 PM
Evaporator Drain Tube? -Joe- ZJ Grand Cherokee Forum 3 05-23-2005 12:33 PM
