-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   sunroof rear drain tube replace (http://www.jeepforum.com/forum/f67/sunroof-rear-drain-tube-replace-1317466/)
selkplitt 01-21-2012 11:32 AM
Was curious if anyone has experience in replacing the rear passenger side sunroof drain. I have removed the headliner and blown air in but can still tell there is an obstruction although some air goes through. I closed it back up hoping it was enough but it wasn't. I bought a new drain tube for the $5.00. My question is, when the tube goes down the c pillar, can i just pull it out or do I need to remove the lower trim to get to pieces that hold it in place. Trying to figure this out before I start tearing it apart again.
Thanks for any help.
07 commander sport
mdamen 09-29-2013 07:40 PM
I just went through this on my 05 GC. You can't get to the tube once it goes into the C pillar. I took out the rear seat and all the trim and you can't see anything.
Looking under the car, I can only see a small drain hole that is filled with foam. After the drain tube is installed, they shoot foam into the cavity for sound deadening. It tends to dislodge the end of the drain tube and plug it with foam. I do not know of a way to get to the end of the drain tube at the bottom of the C pillar.
The time now is 06:03 PM.
