Suggested Preemptive Maintenance 100K - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Suggested Preemptive Maintenance 100K
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitEngo winches available at www.rockridge4wd.com! Free shipp
Unread 10-27-2013, 11:39 AM   #1
0321Nick
2006 WK
Hey y'all,
I'm about 2300 miles from hitting the ole 100,000 on the odometer. What's some suggestions for preemptive maintenance?
I take pretty good care of the jeep: frequent oil changes; diffs at 30K, 60K, 90K; spark every 30K; etc.
I know the big thing at 100K is the get the radiator flushed, what else are some good ideas?
-Replace tire rod ends?
-Replace front sway bar bushings and links?
-Flush/Fill all fluids (i.e. brake fluid, power steering)?
KHAKI CLUB #65
2006 WK 4.7L V8 - Modified OME HD with Bilstein 5125s (28" length); JBA UCA; JKS Rear Discos; K&N CAI; PowerStop Discs; HyperTech; TOYO Open Country AT IIs 285/70/17; + some other goodies
0321Nick is offline   Reply With Quote
Unread 10-27-2013, 12:37 PM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Originally Posted by 0321Nick View Post
Hey y'all,
Honestly, looks like you have all the bases covered. Only because it wasn't mentioned I'd add the t-case to that list but I imagine you service that as well. Throttle body cleaning. Maybe consider swapping in a new tstat and water pump when you drain the coolant for a flush/refill. Keep up the good work!
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote
Unread 10-27-2013, 12:52 PM   #3
TurboDiesel
2008 WK
transmission
[B]-]All Blacked Out[-[/B]
2008 Jeep Grand Cherokee 3.0 CRD
2" RC lift
255/75R17 BFG KM1's
17" ion alloy rims
15" kicker solo baric L7 w/ Alpine m1000 amp
aftermarket headlights w/5000k HIDs
Red interior LEDs and Red license plate LED
Tinted tails
5% tint over the rear windows
more to come....
TurboDiesel is offline   Reply With Quote
Unread 10-27-2013, 03:51 PM   #4
caulk04
2008 WK
I like to do auto transmissions every 50.
Brake fluid should be done every two years.
The power steering fluid so nasty on our hemi at 40k that I plan to do it every 30 or less.
Hard parts get replaced as they fail for me, I keep a close eye on them instead of keeping a mileage schedule.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote
Unread 10-27-2013, 08:03 PM   #5
0321Nick
2006 WK
I'm definitely over due for the brake fluid and steer fluid.
That's my plan too with the hard parts - I do toy in my head with just going ahead and replacing the water pump and alternator. But it would probably be better to just preemptively put new hoses in everything instead.
KHAKI CLUB #65
