studs broke on wheel spacers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > studs broke on wheel spacers
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDRear Disc Brake Conversion Kit- TJ,YJ,XJSWAG 50 Cal Ammo Can Mount With M2A1 Can
Unread 07-06-2014, 08:10 AM   #1
Dylon531
2005 WK
Drove up to PA for the 4th to see girlfriends family, yesterday I made sure all the lug nuts were tight and 2 broke off. Bought them from 4xguard 2 months ago.
Would there be any problems driving back with just spacers on the front?
Airborne Infantry
2005 WK 4.7
OME HD, 265/70 Duratracs, Rola roof rack, superchip flashpaq 3872
Dylon531 is offline   Reply With Quote
Unread 07-06-2014, 11:28 AM   #2
bersh
2008 WK
Doesn't sound like you have a choice. What brand spacers?
bersh is offline   Reply With Quote
Unread 07-06-2014, 11:39 AM   #3
Dylon531
2005 WK
Im not sure the brand but its the only kind they sell on 4xguard
Airborne Infantry
2005 WK 4.7
Unread 07-06-2014, 11:41 AM   #4
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
What did you torque them to? I'm guessing you over torqued them.
Sorry to answer your question, you should be fine without spacers on the rear unless your tires rub without them. What lift and tires do you have? You don't have your vehicle info filled out
See How It Was Made
Omelet is offline   Reply With Quote
Unread 07-06-2014, 11:44 AM   #5
atarijedi
2008 WK
Are they the blue ones? If so, they are Spidertrax I believe. You should contact Spidertrax about it. They have a limited lifetime warranty. So if it was a material failure, you could get a new set free.
http://www.spidertrax.com/
atarijedi is offline   Reply With Quote
Unread 07-06-2014, 11:54 AM   #6
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Possibly! Unless the install directions were not followed correctly, them I'm sure the warranty is void. They have a specific torque setting like most bolts.
See How It Was Made
Unread 07-06-2014, 12:19 PM   #7
Dylon531
2005 WK
OME HD lift with 265/70 duratracs on stock wheels. Doesn't seem to be rubbing but I wasn't sure if it would screw anything up running spacers up front and not on the rear
They were torqued to 100 ft lbs
Airborne Infantry
2005 WK 4.7
Unread 07-06-2014, 01:06 PM   #8
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
No you're fine with those tires. The rear will have a narrower track width than the front, but that won't be a problem for your drive home.
I'm sure 4xG will work with you, I'm not sure how Spidertrax is with warranty issues. You might want to read their warranty first as they might require them to be installed by an authorized installer? I know some companies will have that in there!
See How It Was Made
Unread 07-06-2014, 07:43 PM   #9
luckyse7ens
2010 XK Commander
Oh man... I want spacers, but I keep finding these horror stories.
Black WK Club #152
luckyse7ens is offline   Reply With Quote
Unread 07-07-2014, 04:19 AM   #10
tjkj2002
2002 KJ Liberty
Cheaper/safer to buy rims with the correct back spacing in the 1st place.
tjkj2002 is offline   Reply With Quote
Unread 07-07-2014, 05:23 AM   #11
paroxysym
2007 WK
had the same thing happen to me on one of my old 1" wheel spacers.... i had 3 studs break off on it and the wheel fell off when i came around a curve.. no damage to the jeep other than snapping my bilstein shock in half as the tire folded into the wheel well.
i dont remember the name, but im going with over-torqueing of the wheels as the cause. ill run them again one day but for now i dont need them
2007.5 WK Laredo 4.7
OEM+
paroxysym is online now   Reply With Quote
Unread 07-07-2014, 05:29 AM   #12
bersh
2008 WK
Suggestions?
Unread 07-08-2014, 11:03 AM   #13
luckyse7ens
2010 XK Commander
Cheaper? I haven't found wheels any cheaper, unless your accounting for damage due to spacers.
Black WK Club #152
