Strange vibration..... '06 WK - JeepForum.com
 1Likes
  • 1 Post By Mp5ben
post #1 of 10 Old 03-16-2017, 10:56 AM Thread Starter
rutro
2006 WK
'06 WK limited w/130,00 +. This starts about 60-70 mph, just a vibration and I can't tell from front or back, no noise. It will stop if I slow it down to 50-55, but tries to get worse if I speed up and try to drive through it. Generally speaking it won't come back, for a good while. Some times several months but the Jeep is not a daily driver, gets used for running to hardware, lumber yard, boat ramp ect. I've been looking at the search threads and will check some more underneath but it's got me stumped. Any ideas I would appreciate....
#5 Black '06 WK limited quadra drive 4.7
rutro is offline
post #2 of 10 Old 03-16-2017, 11:25 AM
Mp5ben
2005 WK
When is the last time you had tires replaced or balanced?
underscore likes this.
05 WK Limited, HEMI 5.7, QD II, OME HD, 255/75/17 Mud terrains
Mp5ben is offline
post #3 of 10 Old 03-17-2017, 01:53 PM Thread Starter
rutro
2006 WK
Well it's been a year. I would expect a tire/wheel out of balance would be a constant thing. Not an ever once and a while thing like this is. I've had little globs of mud, a bit of packed sand ect make a vibration before, it won't quit until it's removed. And if big enough it'll make ya go to the shoulder and find it, because otherwise you'll be white knuckled worrying what it is. This starts off just noticeable and gets progressively worse as speed increases. I've never had anything quite like it happen before.
rutro is offline
post #4 of 10 Old 03-17-2017, 03:11 PM
Mp5ben
2005 WK
I would still have the tires balanced and rotated. Tires go through alot of wear and issues might appear on different textured surfaces and roads. It would help to eliminate wheels and tires at least so you can start looking elsewhere.
Then climb under and inspect for anything that looks out of place or very worn.
Aldo might be one of your driveshafts starting to go out. Mine vibed pretty bad when a u joint went bad, when I pulled it out it didn't have any range of motion at all to it!
Mp5ben is offline
post #5 of 10 Old 03-18-2017, 08:57 AM
Dinner
2007 WK
I had a similar problem dealer couldn't figure out. Mainly use my Jeep for towing, not my daily driver either. It was very intermittent, I finally connected the dots and realized it was a sticking rear emergency brake, left side. I started off and when I heard the noise start near highway speeds, pulled over and checked rear brakes. We have the drum e-brake inside the disc. Right side was cool, then nearly removed my finger prints on the left side so be carefull. The slider cam that was really stiff, I think the heat helped it relax then the problem went away until the next time. Jeep was new to me at that time and passed cert at a Jeep dealer so one would think they checked this kind of thing. The component I am referring to doesn't come with the rebuild kit, it is the piece where the cable connects and makes shoes spread apart. Dealer's mechanic even took it home one night and said yup it happened, all fixed, we balanced and rotated tires. Then it happened to me again.
Dinner is offline
post #6 of 10 Old 03-18-2017, 10:05 AM Thread Starter
rutro
2006 WK
Hey thanks for those replies. I've been wondering/worrying about a drive shaft. That was one of the first things I checked after the first time this happened. But they were both tight with no play at all.... which seems to mean nothing with these new ones. Now that e-brake has my attention. I never would have thought about that. I knew they were inside the rear disc/wheel drums. I can see that driving a man to distraction with no trouble at all. Something about the way the e-brake handle pulls and releases on this one is not quite like my old '05 was. I use it a lot especially on the boat ramps.... don't need to go to the deep 6 car wash.
rutro is offline
post #7 of 10 Old 03-18-2017, 12:44 PM
Mp5ben
2005 WK
My rear driveshaft had no play in it when i checked it under the vehicle and it was reallyyy bad. I would remove it from the Jeep to check the movement of all the joints. AND, it is non rebuildable..so you have to shop for a new one
I bought a new shaft on Ebay that has standard U joints so you can replace a $10 part instead of a new shaft each time
Mp5ben is offline
post #8 of 10 Old 03-18-2017, 01:35 PM
durango-bob
2006 WK
Check all your brakes when it happens. A dragging caliper can overheat the rotor and cause it to warp. When it happens, pull over and see if any of the brakes are significantly hotter than the others.
durango-bob is offline
post #9 of 10 Old 03-19-2017, 08:46 PM
Rojahdatt
2008 WK
I also had this problem.... Like others said check your brakes.
For me it tuned out to be the e-brake shoe liner on one side detached and was dragging.
I also came across one guy who suspected it was a worn rear spring causing some sort of harmonic vibration.
Rojahdatt is offline
post #10 of 10 Old 05-06-2017, 08:39 PM Thread Starter
rutro
2006 WK
Well after all this time it finally did it again today. Driver side rear brake drum was smoking hot. None of the others were even warm actually, but that drivers side rear was HOT. I bent over to look at it first and that's when I smelled it, good thing because it could have pulled the hide off my fingers. Now I know where to look and it's almost got to be the e brake. Thanks Dinner and durango-bob for the heads up on this, I would have been scratching head still talking to myself.
rutro is offline
