Strange clunking at low speeds when wheel is being turned*video attached* - JeepForum.com
post #1 of 13 Old 06-17-2017, 10:30 PM Thread Starter
Hamass88
Hi guys I've had a lot of work done on my jeep and a lot of money spent and the problems just keep coming,my latest problem is a strange clunking (not ball joints or control arms I had both sides replaced) when steering wheel is turning to the right or left at slow speed like underground car park speed,any help with this is greatly appreciated I'm over 5 g's deep in repairs and I bought the jeep 3 months ago just can't force myself to sell it,she's a beaut I'm gonna attach a video I took in our underground car park( https://youtu.be/EKkoWgVa2hU)
Hamass88 is offline
post #2 of 13 Old 06-17-2017, 11:49 PM
underscore
2007 WK
Do you have QDII?
2007 WK CRD QDII
underscore is offline
post #3 of 13 Old 06-18-2017, 09:12 AM
chance_p
2008 WK
Before watching your video, based on your description, I would say either wheel bearings or CV shafts.
After watching the video, it sounds like a bolt didn't tightened when somewhere.
08 WK 4.7 QTII - 4" Superlift - JK Moabs - 265/70 Cooper AT/3 - Flashpaq
chance_p is offline
post #4 of 13 Old 06-18-2017, 11:25 AM Thread Starter
Hamass88
Originally Posted by underscore View Post
Do you have QDII?
yea bud qd11
Hamass88 is offline
post #5 of 13 Old 06-18-2017, 11:26 AM Thread Starter
Hamass88
yea that's what I was thinking also,some thing silly like that,I had the rack and pinion replaced when I first bought and it seems to be coming from that area and especially when steering is turning but I don't know
Hamass88 is offline
post #6 of 13 Old 06-18-2017, 04:32 PM
underscore
2007 WK
Originally Posted by Hamass88 View Post
yea bud qd11
Sounds like what mine did when the front diff fluid was old and the additive had worn out. After a drain and fill it took a bit for the new fluid to fully circulate but once it was it was good to go.
2007 WK CRD QDII
post #7 of 13 Old 06-18-2017, 05:18 PM Thread Starter
Hamass88
yea bud qd11
Jesus I'd love if that was the case,my mechanic just changed bushing on front diff and changed fluid and I hope he added the addictive,but since I got it back 4 days ago it has gotten a lot worse
Hamass88 is offline
post #8 of 13 Old 06-18-2017, 05:40 PM Thread Starter
Hamass88
So I just tried the jeep while it was running but in park and the bang still happened on slow turn of the steering wheel to the right?
Hamass88 is offline
post #9 of 13 Old 06-19-2017, 10:53 AM
underscore
2007 WK
Probably not the diff fluid then. If you can do it in park can you have someone make the noise while you crawl underneath and listen for it? Does it make the sound with the key in and the engine off?
2007 WK CRD QDII
post #10 of 13 Old 06-19-2017, 02:28 PM Thread Starter
Hamass88
good idea bud gonna try that this evening,thanks man
Hamass88 is offline
post #11 of 13 Old 06-20-2017, 11:27 AM
bensylrm
2005 WK
Mine was doing something like this a few years ago when I had similar work done. I can't remember which part of the tie rod it was... one of them was not tightened down enough, and caused a popping/clunk sound. Wish I could be more specific, I just don't remember. I do know that I drove on it for a few weeks (not driving everyday) trying to figure it out. This caused an entire tie rod, inner and outer, to be replaced. Eventually, I was able to jack up the entire front end and wiggle the driver side Tire left and right without moving the passenger side Tire. It made steering a little interesting... and then back to Firestone for an alignment. Love the lifetime alignment.
Sent from my LG-H810 using Tapatalk
05 WK 4.7 OME HD F150 MLL's, BFG MT 255/75-17. Lots of stickers, lights EVERYWHERE!
bensylrm is offline
post #12 of 13 Old 06-20-2017, 11:37 AM
jeepstercanada
Check the control arm bolt. Mine were loose as they are adjusters for caster and camber on alignment. Shop never tightened then enough
jeepstercanada is offline
post #13 of 13 Old 06-20-2017, 12:11 PM Thread Starter
Hamass88
Thanks guys I spent a couple of hours last night trying to get to the bottom of it and it seems to be coming from the middle of the under carriage,like where the engine cover is under the jeep,I had rack and pinion replaced and I'm pretty sure mechanic removed the steering box to do this,is it possible that this could be the source
Hamass88 is offline
