Stock WK HID Output Versus MH1's - JeepForum.com
post #1 of 7 Old 12-15-2011, 08:10 PM Thread Starter
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Avatar
2015 JK Wrangler
So my buddy enjoys the output of HID's but is too lazy to do a real retro. I researched quite a bit about his new vehicle, a 2009 Jeep Grand Cherokee WK. From all the posts I found, the output (even with HID's) has a decent cutoff. I was somewhat disbelieving, but figured if that's what he wants, it's his vehicle. With the output nothing like a Honda Civic lol. He installed his PnP kit today and I grabbed a few shots before I left work. On the one side is my Grand Cherokee ZJ, with Morimoto MH1 3.0's and a VVME 35 watt, 4300K PnP kit. On the other is his Grand Cherokee WK with a stock housing and VVME 35 watt, 4300K PnP kit. He also did his fogs, but they glare like all hell, so I didn't even bother taking photos of that. Also, I am aware my passenger side is not rotated properly. It's zip tied in as I hit a tree and have a body shop appointment after the Holidays.
MH1 Left - PnP Only Right:
His PnP Output Only:
Above His Cutoff:
Below His Cutoff:
Side by side Above Cutoff:
Side by Side Below Cutoff:
-Rick R
-2015 JKU - 3.5" JKS JSPEC Kontrol, 315/70R17" MTZ's, 17x9" Quadratec Rubicon Xtreme's, JCR bumpers & skids, JW Speaker tails, Dirty Dog netting/screens, Quadratec Auto Mirror Movers, etc
-03 VW Golf TDI - Diesel
-FDNY 9/11/01 - All gave some. Some gave all.
PAFirefighter11 is offline
post #2 of 7 Old 12-16-2011, 12:50 AM
Pac Man
Pac Man's Avatar
Those are stock halogen housings? Mine scatter a lot more than that!
2007 Black Grand Cherokee
Hemi - QDII - OME - S4XC Hidden Winch Mount -Talon 9.5SR - Full Matrix - 265/70/17 Duratrac's - Pintlers- Superchips - Magnaflow - Airaid - 5000k HIDs - Lightforce HID's - 4xG Front Guard - 4XG Diff Cover
Pac Man is offline
post #3 of 7 Old 12-16-2011, 08:17 AM Thread Starter
PAFirefighter11
2015 JK Wrangler
Yep, stock halogen housings with a VVME PnP kit in the WK. I was shocked how tolerable it was. He just needs to not run the fogs unless there is no oncoming traffic. Those fogs have tremendous glare.
-Rick R
post #4 of 7 Old 12-16-2011, 09:41 PM
Sohcvtec1995
i have pnp on my wk and out put and cut off is very similar to your buddies.
Sohcvtec1995 is offline
post #5 of 7 Old 11-08-2012, 01:10 PM Thread Starter
PAFirefighter11
2015 JK Wrangler
I'm very surprised at how decent of a cutoff and how lacking in glare that setup actually is.
-Rick R
post #6 of 7 Old 11-08-2012, 08:58 PM
Budasac
2005 WK
If you do the fogs you can't go any brighter then 35w 3000k or they're completely blinding. I saw WK with 6000k and they were annoying in daylight. As far as the low beams go, I have a DDM kit in mine and the cut-off is fine. There's more of a glare off my stock fog lamps then my HID low beams.
Budasac is offline
post #7 of 7 Old 11-09-2012, 12:45 AM
1dzlwk
2007 WK
The difference between 3000k and 6000k has nothing to do with actual brightness, it's just a difference in color temperature, with 3000k looking rather yellowish in color and 6000k looking more bluish. The color difference may cause a difference in perceived brightness, though.
The reason the H.I.D. conversion works so well on the WK low beam halogen housing is that there is a mechanical shadow mask built into the housing that prevents any of the light that's coming out of the tip of the bulb from leaving the lens without first being directed/controlled by the reflector. It's a nice conversion...that I may just do on my wife's WK.
The reason that the converted fog lights ended up becoming flood lights instead is that the fog light housings do not have a shadow mask...so the light coming out of the bulb tip just blares out through the lens completely uncontrolled.
____
Bob
1dzlwk is offline
WJ V8 versus I6 ride height firejeep344 ZJ Grand Cherokee Forum 8 06-09-2009 02:17 PM
New 4.7 versus Hemi? ray40 WK Grand Cherokee & XK Commander Forum 4 01-14-2008 03:04 AM
5.9 versus RR? udmover ZJ Grand Cherokee Forum 6 12-12-2006 07:36 PM
ZJ versus WJ greygrand ZJ Grand Cherokee Forum 36 03-20-2006 05:16 PM
stock alt. output? rhetor22 ZJ Grand Cherokee Forum 2 12-18-2003 07:40 PM
