Stillen Side Marker Covers Question - JeepForum.com
post #1 of 16 Old 04-13-2013, 06:46 PM Thread Starter
seanmc
2008 WK
I have a quick question about the Stillen headlight side marker covers I just received in the mail. I am wondering if it is safe for me to just sand, prime, paint and install these myself. I am no means a paint/body work expert or very handy with mechanics like some of you on here but I can manage the minor DIY projects here and there. It comes with directions on how to install, just have to remove the grille, that's pretty simple right? I don't really want to bring it to a shop and pay for something if I don't have to. My WK is black, when buying the primer and paint, is it safe to go with the color match chrysler spray paint at my local auto parts store? I tried searching the topic but couldn't find an answer, If anyone has done this before or has any advice I would greatly appreciate it.
Thanks guys, I just got this car this week and have done some minor mods, and will post some pictures soon!
Black 2008 WK | 3.7L | QTI | More mods to come...
seanmc is offline
post #2 of 16 Old 04-13-2013, 07:45 PM
super_SINGH
2006 WK
I have my stillen painted and primed universal black by Duplicolor. I have a white 06 wk though but if you want color match, paint them Chrysler/Dodge/Jeep black. I did 2 coats primer and 4 coats paint -NO clearcoat fro me because I didn't want it shiny, but you might have to use clearcoat because I think your black Jeep might have clearcoat.
I also cut my side markers like the AVS headlight covers and I also have no experience doing it and you can see I messed up on one side with a ****ty saw that I got free from Harbor Freight Tools.
ONLY pic I have for now
super_SINGH is offline
post #3 of 16 Old 04-13-2013, 07:48 PM
super_SINGH
2006 WK
ALSO I installed mine twice now, once unpainted (as the pic above) and a second time after I painted and primed them. They were super easy to install & uninstall (you don't really even have to remove the grille, just bend it, but it's easy to remove anyways). The tape preinstalled on those is strong yet easy to remove and when i reapplied mine I just added some 3M tape (strength rating 2) where the old red tape was. I haven't installed them the second time yet (paints still drying) but I will upload pics when I do.
post #4 of 16 Old 04-13-2013, 09:15 PM
cherrybomb05
2010 JK Wrangler
I would suggest getting it painted. It needs a special type of paint due to the material it's made out of. That's what I learned anyway
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline
post #5 of 16 Old 04-13-2013, 10:51 PM
hxdrummerxc
2008 WK
I was under the impression that these wouldn't fit the 2008+ models because the slight headlight style variation. These have a flat bottom like the 2005-2007. As where out 2008+ bumper isn't flat to conform to the cover.
Can anyone confirm that they do in fact fit on 2008 or newer models?
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline
post #6 of 16 Old 04-13-2013, 11:05 PM
super_SINGH
2006 WK
Just checked with stillen. These headlights covers only fit the jeep grand Cherokee model years 2005-2007. So they most likely will not fit on an 08. I haven't tried personally though,.if the design is only a little different from the 05-07 then you could probably mod them if you really wanted to.
post #7 of 16 Old 04-13-2013, 11:27 PM
hxdrummerxc
2008 WK
Thanks for confirming that
The OP seanmc said he received his in the mail already but in his signature it says that he has a 2008. Looks like you might need to send them back or mod them to try and fit.
post #8 of 16 Old 04-13-2013, 11:31 PM Thread Starter
seanmc
2008 WK
They make them for both 2005-2007 as well as 2008-2010.
http://www.stillen.com/product/light...98gltk9storoi4
seanmc is offline
post #9 of 16 Old 04-13-2013, 11:59 PM
super_SINGH
2006 WK
Those look like s diff design though, can you post a pic of them in the same position mine are in the pic above ?
post #10 of 16 Old 04-14-2013, 12:28 AM Thread Starter
seanmc
2008 WK
Yeah they are smaller, the same on the side where the reflector would be but then they cut off where it ends. Doesn't have the whole bottom part, I'm guessing because the bumper/headlight is different than previous year models. It just covers the side marker reflector not the bottom of the headlight. Will post pictures tomorrow if I can figure it out lol, probly going to attempt to paint/install myself.
seanmc is offline
post #11 of 16 Old 04-14-2013, 10:36 AM
super_SINGH
2006 WK
Make sure to give them sufficient time to dry, and use some clear coat to match your factory colors because they will be taking a lot of dirt and bugs and will scratch easily otherwise
post #12 of 16 Old 04-14-2013, 12:26 PM Thread Starter
seanmc
2008 WK
Thanks for the advice I'll update this thread while I'm doing it.
seanmc is offline
post #13 of 16 Old 04-14-2013, 03:17 PM Thread Starter
seanmc
2008 WK
Well I can't find the "acrylic" based primer Stillen recommends to use, so it looks like I have to take it to an auto body and paint shop. How much should it be to paint these small things?
seanmc is offline
post #14 of 16 Old 04-14-2013, 03:37 PM
super_SINGH
2006 WK
honestly man you do not need to take it to a Paint and Body Shop just sand it down real good then Prime it with a couple coats and paint add with a couple codes and then put some clear coat over it and you'll be good to go.
don't waste money, spray paint cans(primer,paint,clearcoat) and sheet of sand paper isn't going to be over $20. And takes no time at all since they're so small. Most of the time is spent waiting between coats.
I've never painted in my life before, but I manage to do it just look it up online, watch videos if you need but do it YOURSELF!
post #15 of 16 Old 04-14-2013, 06:58 PM Thread Starter
seanmc
2008 WK
Yeah that's what I wanna do but is alright to just use regular paint primer? Is that what you used and it was okay. What grit sand paper did you use before and after priming it?
seanmc is offline
