Steering Wheel Clicking - TSB repair, can i do it? - JeepForum.com
post #1 of 46 Old 06-26-2009, 07:39 AM Thread Starter
jbwest17
My wife's '05 has a clicking in the steering wheel when you turn it. It exhibits the symptons covered in TSB 1900505.
http://www.wkjeeps.com/tsb/tsb_wk_1900505.pdf
I'm wondering if I can do this myself. I handle pretty much all the maintenance on the car, but not so sure about removing the steering wheel. The dealer wants at least $150 for labor, assuming that is the problem. Knowing them, they'll probably tack on some more for "diagnosis".
Thanks.
jbwest17 is offline
post #2 of 46 Old 06-26-2009, 09:43 AM
Texas WJ
Texas WJ's Avatar
2005 WK
Are you comfortable removing an airbag?
Texas WJ is offline
post #3 of 46 Old 06-30-2009, 11:51 PM
dcaprio
2005 WK
I did this repair myself in about 15 minutes. Vey easy and worked like a charm. Key is disconnecting battery and waiting like 15 mins for capicitors to discharge. Then it is easy. Have a Service manual?
dcaprio is offline
post #4 of 46 Old 07-02-2009, 06:32 PM
sammy29926
Hi Dcaprio,
My wifes 05 Jeep is doing the exact problem. How can I fix it? If you tell us step by step instructions that would be great. which part did you buy?
Sammy
sammy29926 is offline
post #5 of 46 Old 07-02-2009, 07:22 PM
Acidcold
2005 WK
I have the same problem but can live with it.
Acidcold is offline
post #6 of 46 Old 07-03-2009, 02:53 PM
dcaprio
2005 WK
To Sammy and others,
I found this repair to be pretty easy for a Jeep repair. I ordered and purchased part #05143321AA from my local dealer. It took a day to come in. This is the SCM Cancel Cam. I spoke to the service manager about how to repalce and he was extremely unhelpful. A nearby tech heard me ask him questions and outside he told me to disconnect the neg batt cable, wait 10-15 mins (FSM says 2 mins I think) and then remove the airbag by removing the two screws behind the steering wheel (behind the horn, from the back). Remove the steering wheel (I used a steering wheel puller, avail for rent from Autozone). He said after that I would be able to figure it out and it was really easy. So I did that, removed the airbag, and then removed the steering wheel. I removed the shroud around the steering column by removing the two? screws under the steering column. It comes off in two pieces, one one top and one on bottom. At that point I kinda pulled out the SCM (Steering control module) and saw the small plastic ring that is the SCM cancel cam. I pulled out the old one which was cracked and slid in the new one. I replaced everything in reverse order, replaced the steering wheel, plugged in the airbag and reconnected the neg battery cable. Everything worked great.
The Cancel Cam is just a small plastic ring. The service manager also said it could also be the clock spring, but that was not the case in my situation.
If you attempt this, just be sure to have the part on hand, make sure the steering wheel is straight and wheels are straight before removing and replacing the steering wheel. I was also very afraid of the airbag deploying so I waited a long time after diconnecting the batt cable and did all the work removing the airbag from underneath the steering wheel just in case it deployed.
If you are not comfortable working on the airbag, I would recommend paying the dealer to do this or try to live with the click. To me the click was just too annoying and I thought I would give it a try to save $150-$200 in labor for a $10?? part. It really was a piece of cake. If you do attempt please be careful and good luck.
If you rig is still under warranty they should do this for free. Mine jsut expired so I did myself.
David
dcaprio is offline
post #7 of 46 Old 07-04-2009, 02:49 AM
sammy29926
Hi David,
Thank you for the very usefull info. It is my wifes car and It is not under warranty except the powertrain. I will order the part and try to tackle this. It sounds like a easy thing to do. I will try to take pictures of it so in the future if any of this forum members need to do this fix they will have the info.
Sammy
post #8 of 46 Old 07-13-2009, 07:55 AM
dcaprio
2005 WK
Sammy, have you tried it yet? Curious to see how it worked out for ya.
dcaprio is offline
post #9 of 46 Old 07-21-2009, 04:18 AM Thread Starter
jbwest17
I thought this thread had died out and wasn't following it. Thanks for the instructions dcaprio. I may go ahead and give this a shot.
One question, the TSB says you need a second part #06505656AA, a steering wheel bolt. I assume that can be reused since you didn't mention it.
jbwest17 is offline
post #10 of 46 Old 07-21-2009, 07:36 PM
dcaprio
2005 WK
I reused mine, just put some new loctite on it.
dcaprio is offline
post #11 of 46 Old 08-08-2009, 11:39 AM
sammy29926
Hi guys ,
I did it this last saturday and It was easiyer than I tought it wouldbe . I took pictures and i will post them in 10 minutes...
Sammy
post #12 of 46 Old 08-08-2009, 01:05 PM
sammy29926
Here is the instructions with the pictures. what Dcaprio posted earliyer is the way to do it. I took notes and pictures that anybody who wants to tackle this jobmight find it helpful.
Take the Steering Wheel Columm Cover screws out. They are T-15
http://i111.photobucket.com/albums/n...eelfix002m.jpg
http://i111.photobucket.com/albums/n...eelfix003m.jpg
http://i111.photobucket.com/albums/n...eelfix004m.jpg
http://i111.photobucket.com/albums/n...eelfix005m.jpg
This what it would look like after taking the covers off.
http://i111.photobucket.com/albums/n...heelfix006.jpg
After that Take the 2 10mm bolts which holds the Drivers Airbag.
http://i111.photobucket.com/albums/n...eelfix007m.jpg
Pull the airbag out to have enough room to disconnect the white connector on the steering wheel and disconnect the yellow airbag connectors on the air bag. Disconnect the Steering Wheel Radio controls too.
http://i111.photobucket.com/albums/n...eelfix008m.jpg
http://i111.photobucket.com/albums/n...eelfix010m.jpg
I rent a Steering Wheel Puller from Autozone.
http://i111.photobucket.com/albums/n...heelfix011.jpg
http://i111.photobucket.com/albums/n...heelfix012.jpg
This what it looks like after pulling th eSteering Wheel out.
http://i111.photobucket.com/albums/n...heelfix013.jpg
http://i111.photobucket.com/albums/n...heelfix014.jpg
http://i111.photobucket.com/albums/n...heelfix015.jpg
Take the 2 T-10 screws for the headlight stalk and take th e2 T-10 screws for the turns signal stalk and slide them out. After that take the 2 T-20 screws out tha take the whole plastic assembly out.
http://i111.photobucket.com/albums/n...eelfix016m.jpg
After that just pop the old csm cancel cam out and pop the new one in.
Then put everthing back together...
http://i111.photobucket.com/albums/n...eelfix017m.jpg
post #13 of 46 Old 08-08-2009, 01:07 PM
sammy29926
Since i do not have 50 posts It does not show the pictures in my post. Could somebody please quote my post and repost it.
Sammy
post #14 of 46 Old 08-08-2009, 07:47 PM
suzieque
2008 WK
nice job! thanks for the great pics! I don't know why the pics don't show up automatically. You didn't show a pic of disconnecting the battery, hope you did that.
By the way, a steering wheel puller is not to expensive and comes in handy, I'd say buy one rather than rent.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #15 of 46 Old 08-08-2009, 07:52 PM
Texas WJ
Texas WJ's Avatar
2005 WK
I'll fix your tags. (You need IMG tags instead of URL)
Nice wright up.
Texas WJ is offline
Clicking when turning the steering wheel lrsmithwhaley WK Grand Cherokee & XK Commander Forum 9 07-03-2015 01:10 PM
Clicking in steering frankie_b11 ZJ Grand Cherokee Forum 3 08-22-2009 06:35 AM
clicking when in four wheel drive joshall ZJ Grand Cherokee Forum 6 04-20-2009 11:59 AM
clicking when turning steering wheel ZJ Limited ZJ Grand Cherokee Forum 11 06-04-2007 02:45 PM
steering wheel clicking noise 99wjman ZJ Grand Cherokee Forum 1 02-02-2006 06:37 PM
