Starting Problems...HELP - JeepForum.com
post #1 of 9 Old 08-31-2010, 07:24 PM Thread Starter
jeepntony
2007 WK
I have a 07 grand cherokee laredo 4x4 with the 3.7 L 6 cyl. I tried to start my jeep this morning and it wouldn't turn over. Not even a click. All the lights come on and the radio works fine. The battery has a full charge and everything is fine. But it won't start. It says that the transmission is overheated. Iv had this problem before and they replaced the Wireless Ignition Node WIN module...it took care of the problem for one month. It cost me 350bucks the first time around. If anyone knws wat the problem is please tell me. I can't figure this problem out...HELP!
jeepntony is offline
post #2 of 9 Old 09-01-2010, 09:05 AM
brutusjeep
2006 WK
Could be the starter. Though the 3.7's don't have many issues with this. But, sounds like a starter to me.
2006 GC Limited, 5.7L HEMI, Quad II. 4XGUARD Belly & Front (black powder coat) skid plates. Matrix front guard, PIAA Matrix mounted lights, 265/70 Nitto Trail Graplers MT, 1.5" Spider Trax spacers, Super Chips Tuner, OME MD Lift, 4XGUARD differential guard, JBA UCA'S.
brutusjeep is offline
post #3 of 9 Old 09-01-2010, 12:19 PM Thread Starter
jeepntony
2007 WK
Yeah I think I fugureed it out. A lot of mechanics said that corssion buildup on the positive side of the starter. And also check the wires from the starter to the control box. There may be corrosion on those too. Thanks for ur help. Ill pull the starter out and clean the wires and regrease everything....thanks again.
post #4 of 9 Old 09-04-2010, 02:29 PM
tju57
I have the same problem
My 2007 4.7 v8 has the same problem. The first thought was the neutral safety switch, but when I called the dealer to get a new switch he said it's not a servicable item. After many questions and about 15 minutes later, the neutral safety switch is incorporated in the transmission solenoid pack, about $350.00.
tju57 is offline
post #5 of 9 Old 09-06-2010, 03:12 PM
Macguba798
2005 WK
Is it throwing a code? When you said, "It says that the transmission is overheated" I'm guessing that's from the code. If so, I would check for trans oil level first and make sure no leaks underneath and lastly tju57 may have a point here.
Good luck with the fix.
Macguba798 is offline
post #6 of 9 Old 09-06-2010, 09:20 PM Thread Starter
jeepntony
2007 WK
Thanks for your input everyone...I really appreciate it. This past weekend I took apart the starter and cleaned all the connections on the battery, starter, ground to the engine block,ect. With terminal cleaner and wirebrushed everything, then swabbed everything with electrical grease. It feels like it starts better than it ever has. When I took the positive and negative connections aart from the starter...they were really loos! So ir was probably a connection problem. Knock on wood!!! But I still don't understand the whole "transmission overheat" warning on my dash. There were no leaks underneath and I still have to take it to a dealer in order to get the fluid checked. There Is No Dipstick...WEIRD! If anyone knows if u can install one on an 07 3.7 V6 , please tell me. Again thanks for everyones input.
post #7 of 9 Old 09-07-2010, 01:55 PM
mdsbigpapa
2005 WK
OK, here's my best guess as to why the "Transmission Overheat" message was displayed. Whenever I tune my Jeep with the Flashpaq, I get the same message along with a couple of others that escape me right now. The tuner requires the BUS to be interrupted so it can perform its magic. I believe it is very similar to a power loss to the PCM. Given this, and your dirty terminal/loose connections, there may have been a slight power interruption to the PCM which caused the "Transmission Overheat" message.
Mark, a.k.a. MDSBigPaPa - 2005 Grand Cherokee Limited, 5.7L Hemi, AMSoil (0W30 SSO, transmission, transfer case, front & rear diffs, coolant, power steering), NGK 2313 plugs, Taylor Shorties, Jet 180 thermostat, Superchips 3875 w/ Advanced Trans Option. Future mods: CAI and CAT-back exhaust. Hemi Club Member #46A and 46B
mdsbigpapa is offline
post #8 of 9 Old 09-07-2010, 03:03 PM Thread Starter
jeepntony
2007 WK
Oh ok...that would explain this whole mess. Because when it was starting whenever I yanked on the negaitive cable. The message would still show up. But after I cleaned, brushed, greased, and retightened everything the message has gone away. Thanks
post #9 of 9 Old 09-07-2010, 03:42 PM
stanton3
2007 WK
Mine did the exact same thing, had to get a new starter. Still says transmission over temp a few months after, but has been fine ever since. Never threw a code either.
2007 WK 4x4 | OME HD 3" Lift | OME Shocks front + rear | 265/70/17 BFG All Terrains | 1.25" Wheel Spacers on stock wheels | Saguaro4xcomponents 5/8" Front recovery shackles | Aries Taillight Guards | PIAA 510 fogs in stock location | Midland 1001z Cb | Mopar Rear recovery hook | Rola Roof Rack |2 Hella 500ffs mounted behind grill | Firestick 3' Antenna | Saguaro Antenna Mount | Front Bumper Cut/Fender Trim | OEM Front suspension skid | 4xguard Front skid | Rusty's .5" Front Spacer | Lots more to come
Want to buy: 4xguard Rear Guard
stanton3 is offline
problems starting brammabull69 ZJ Grand Cherokee Forum 4 02-08-2009 12:55 PM
Starting problems Adriansaxton ZJ Grand Cherokee Forum 3 02-26-2007 11:21 AM
starting problems mishnoff ZJ Grand Cherokee Forum 3 02-17-2006 07:42 PM
00' GC 4.0 L starting problems. Tazz ZJ Grand Cherokee Forum 12 11-29-2005 08:39 AM
Starting Problems ddoffroad ZJ Grand Cherokee Forum 3 04-06-2005 11:04 AM
