Stalling after cleaning injectors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Stalling after cleaning injectors
JKS Flex Connect in Actions!CCOR is Hiring! Athens, GA!ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 11-25-2014, 08:31 PM   #1
alberto68888
2008 WK
Few months ago i did a ultrasonic fuel injectors cleaning and days after that my wk (2008 4.7L) start to stall in traffic having no dtc codes and no CEL. It stall everytime now even while driving, took it to a lots of mechanics and still stalling, really got me crazy. Any ideas?
alberto68888 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2014, 08:37 PM   #2
technologic80
2005 WK
I thought I read that a bad EGR valve can cause stalling.
technologic80 is offline   Reply With Quote Quick reply to this message
Unread 12-15-2014, 03:31 PM   #3
alberto68888
2008 WK
I havent changed the EGR, but replaced the crankshaft, camshaft sensor, pcv valve and spark plugs. Also tested the fuel pressure and its 60 psi. Its stall about 5 times in a day and no codes. All start after the injector cleaning, a bad injector should throw a code? Also when stall all the electronic system works, the engine just shut off and start again shifting neutral.
Unread 01-23-2015, 02:39 PM   #4
alberto68888
2008 WK
So did another injector clean and stall gone about 3 days and back again. When stall it will crank 2-3 times and start again. Could be the fuel pump failing?
Unread 01-23-2015, 04:45 PM   #5
Hendrix9
2007 WK
Question- what made you think to do the initial injector cleaning? Was it acting weird? Just curious.
2007 CRD QDII- ROR springs on 265/70/17s
2010 Jetta Sportwagen TDI 6MT - Stock for now...
Hendrix9 is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 07:02 AM   #6
alberto68888
2008 WK
Well ive heard that many people complaints about the gas sold here, they say that its too dirty and the fuel filter and injectors gets clogs. I didnt find any fuel filter replacement and i think that if there is a bad injector, at least i will get a dtc. So im wondering if could be the fuel pump causing the stall.
Unread 01-24-2015, 07:56 AM   #7
RCS1300
2005 WK
Check your fuel pressure at the fuel rail. It should be about 55 psi or higher. If the fuel pressure is lower, you may have a clogged fuel filter or weak fuel pump. Unfortunately, I believe the fuel filter is within the fuel pump assembly so you change them out as a unit.
RCS1300 is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 08:16 AM   #8
alberto68888
2008 WK
I did check fuel pressure and got 60psi but the WK is now with 56k so i dont know if its time to change the fuel pump.
Unread 01-24-2015, 09:19 AM   #9
RCS1300
2005 WK
If you have 60 psi the fuel pump and fuel filter are fine. Do not change them. Something else is causing the problem.
Have the spark plugs been in the Jeep more than 30,000 miles?
Unread 01-24-2015, 10:19 AM   #10
alberto68888
2008 WK
Only 10k miles. But when it stall the radio, a/c, headlights still on so i dont think about an electrical issue. Trans fluid is on top, crank/cam sensor replaced, pcv valve replaced too.
Unread 01-24-2015, 10:33 AM   #11
RCS1300
2005 WK
Spark plugs are fine at 10,000 miles. No need to change them.
One other item to test is the Idle Air Control valve. The purpose of this valve is to let air into the engine when the air intake is closed during idle. If it is dirty or not working it could cause the engine to stall.
I would first clean it as it could be dirty with carbon buildup. Do not replace it because it is expensive at $80.
But first, check your air filter and make sure it is clean. This could be the issue.
Unread 01-24-2015, 10:42 AM   #12
alberto68888
2008 WK
Do the 4.7 have IAC Valve? Well the air filter its ok too, replaced every oil change. TB cleaned 2 months ago. The thing is it isnt stall only at idle, it stalled once at 50mph, but not always at idle
Unread 01-24-2015, 12:12 PM   #13
Greever
2008 WK
Do you have the wired throttle body? or the electronic one? I also have a 2008 4.7 and mine is electronic and Ive been told not to clean it with regular TB cleaner as it can damage the electronic's in it. Also I dont think the electronic TB has an IAC valve.
Greever is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 12:17 PM   #14
alberto68888
2008 WK
I have the electronic one and only cleaned up twice. I want to be sure that its something bad before doing anything, fuel pump isnt cheap about 200$. But the guy who tested fuel pressure said that should replace the pump.
Unread 01-24-2015, 12:28 PM   #15
Greever
2008 WK
i dont see why he would want to change the pump if the current one is operating at spec.
