The squeaking is killing me - JeepForum.com
post #1 of 8 Old 10-18-2013, 10:30 AM Thread Starter
fafafofi
2006 WK
Installed the lift and drove for a few hundred miles. Now there is a squeaking coming from the strut/spring assembly. Everything is torqued but when you shake it, it squeaks on both sides. It all seems to be seated properly. Help I'm going insane
fafafofi is offline
post #2 of 8 Old 10-18-2013, 10:32 AM
Jeepforthewin
2010 JK Wrangler
Which lift?
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 8 Old 10-18-2013, 10:51 AM Thread Starter
fafafofi
2006 WK
OME with bilsteins
fafafofi is offline
post #4 of 8 Old 10-18-2013, 10:57 AM
paroxysym
2007 WK
somethings not torqued or seated properly... flex it out to seat everything and then see how it is. lol
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #5 of 8 Old 10-18-2013, 02:16 PM
Unsp0kn
Check the swaybar link ends. They were loose when I bought our Commander and it sounded horrible. Torqued them down, no more noise.
2008 Wrangler Unlimited X -3.8L V6 - 6spd - Spyder Rock Bumpers - K&N CAI - 285/70 BFG KM2s - BlackRock D Series 17" - Rigid Industries A-pillar Duallys
2007 Commander Overland - 5.7L HEMI - QDII - 4" SuperLift - 285/70 BFG KM2s - Pro Comp Series 5001 17" - PIAA Fogs
Unsp0kn is offline
post #6 of 8 Old 02-01-2014, 10:39 AM Thread Starter
fafafofi
2006 WK
Still squeaking on both sides! I've unloaded some silicone spray around the springs and such but still not gone. Anyone else have an issue with this setup or have suggestions? Every bump adds a little more insanity to my drive
fafafofi is offline
post #7 of 8 Old 02-01-2014, 12:01 PM
overland-wk
2006 WK
When you installed the lift did you happen to remove the upper control arms? If so check to see if the upper control arm bolts are tight this can also cause squeaking it happend to me.
06 ROR lifted wk (mine)
07 RC lifted xk (wife's)
Youtube channel
Bumsmodified98xj
overland-wk is offline
post #8 of 8 Old 02-01-2014, 12:10 PM Thread Starter
fafafofi
2006 WK
Cool thanks. Probably the only bolts I forgot to recheck.
fafafofi is offline
