Speedo wrong? vs. gps & scanner - JeepForum.com
post #1 of 12 Old 09-28-2013, 08:50 AM Thread Starter
Goldenknob
2007 WK
I hooked up a bluetooth obd II scanner and was checking my speed digitally, with app on my phone. My speedo was showing I was going 70, but the scanner app was showing 67-68. I thought the app could be wrong so I turned on gps speed app and it also showed 67-68.
I am at a loss. My tires are at proper pressure, and are factory size.
Maybe the previous owner had different tires and rims and had the speedo geared? (I've only had the WK for 5 weeks or so.)
Any ideas?
Goldenknob is offline
post #2 of 12 Old 09-28-2013, 09:01 AM
modernblueWK
What size, brand, condition tires do you have? Your tires appear to be undersize.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #3 of 12 Old 09-28-2013, 09:10 AM Thread Starter
Goldenknob
2007 WK
The tires are new. less than 3k miles on them 245/65/17.
post #4 of 12 Old 09-28-2013, 11:24 AM
yzjwk
2005 WK
Any ideas?
Just about all factory speedos (every one i've had anyways) will read a little highter then actual speed .
It may just save you a ticket if your doing 10 over and the cop's radar shows your really only 7 over . the speedo's are calibrated digitally in a wk , so you could have a dealer check if you want or buy a programmer like superchips and set it yourself . you can also go up one size in tires and that will even it out as well .The last option may be why jeeps and SUV's may be a little further out then a car for example , because alot of jeep/suv owners want at least slightly larger tires.
good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #5 of 12 Old 09-28-2013, 04:59 PM
Zlartibartfast
2007 WK
I have seen the same thing - my speedo read high when I had stock size tires on it. Now my tires are 5% over stock diameter and the speedo read approx 2.5% low. I rely on my GPS speedo to give me an accurate indication. When I compare that to those roadside radar thingys they have around here, it (the GPS) almost always matches
Zlartibartfast is offline
post #6 of 12 Old 09-28-2013, 08:33 PM
tjkj2002
2002 KJ Liberty
I just reach down in my center console and either hit the "UP" or "Down" buttons to adjust my speedo to match my GPS while I'm driving.
tjkj2002 is offline
post #7 of 12 Old 09-28-2013, 09:39 PM Thread Starter
Goldenknob
2007 WK
could you better explain how you do that?
post #8 of 12 Old 09-28-2013, 10:01 PM
tjkj2002
2002 KJ Liberty
You can't since you have ABS(not safely) and I went back to mechanical speedo drive with a electric interface to operate the OEM speedo and ODO.
tjkj2002 is offline
post #9 of 12 Old 09-30-2013, 07:27 AM
Radcrd
2007 WK
They are all off, even my previous Liberty was off. Run bigger size tires to compensate next time you change tires. Based on my calculations you would need to be around 30.5'' Diameter to read close to accurate. Stock is 29.5'' Diameter.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #10 of 12 Old 10-03-2013, 10:08 AM
tibo4wd
2008 WK
3 VW TDI's (sold)
Radcrd, like diesel much?
tibo4wd is offline
post #11 of 12 Old 10-03-2013, 12:02 PM
Radcrd
2007 WK
3 VW TDI's (sold)
Just a bit addicted
3 VW TDI's (sold)
Radcrd is offline
post #12 of 12 Old 10-04-2013, 03:31 PM
Walt
2008 WK
Any ideas?
My speedometer reading is several mph different than the DashDAQ XL GPS mph reading. At highway speeds, the speedometer is 1-3 mph higher than the GPS. It reads 70 mph and the GPS reads 67-68 mph. When I get the GPS to read 70 mph, the speedometer reads ~73 mph. Less difference at lower speeds.
[Tires are new and stock size. Inflation at 35 psig. Alignment is good.] As the tires approach end-of-life and the tread wear indicators show, there will be a smaller tire rolling diameter and the indicated speedometer reading will be higher than actual, but not much..........
I believe the speed signal from the WK 545RFE xmission is electrical, not mechanical. To change its input to the dash module, it would take a device with re-programming capability. DashDAQ XL doesn't have that (as far as I know).
That's my story & I'm sticking to it...
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
