-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   Speedo wrong? vs. gps & scanner (http://www.jeepforum.com/forum/f67/speedo-wrong-vs-gps-scanner-1631009/)
Goldenknob 09-28-2013 08:50 AM
I hooked up a bluetooth obd II scanner and was checking my speed digitally, with app on my phone. My speedo was showing I was going 70, but the scanner app was showing 67-68. I thought the app could be wrong so I turned on gps speed app and it also showed 67-68.
I am at a loss. My tires are at proper pressure, and are factory size.
Maybe the previous owner had different tires and rims and had the speedo geared? (I've only had the WK for 5 weeks or so.)
Any ideas?
modernblueWK 09-28-2013 09:01 AM
What size, brand, condition tires do you have? Your tires appear to be undersize.
Goldenknob 09-28-2013 09:10 AM
2 Attachment(s)
The tires are new. less than 3k miles on them 245/65/17.
yzjwk 09-28-2013 11:24 AM
Any ideas?
Just about all factory speedos (every one i've had anyways) will read a little highter then actual speed .
It may just save you a ticket if your doing 10 over and the cop's radar shows your really only 7 over . the speedo's are calibrated digitally in a wk , so you could have a dealer check if you want or buy a programmer like superchips and set it yourself . you can also go up one size in tires and that will even it out as well .The last option may be why jeeps and SUV's may be a little further out then a car for example , because alot of jeep/suv owners want at least slightly larger tires.
good luck
Zlartibartfast 09-28-2013 04:59 PM
I have seen the same thing - my speedo read high when I had stock size tires on it. Now my tires are 5% over stock diameter and the speedo read approx 2.5% low. I rely on my GPS speedo to give me an accurate indication. When I compare that to those roadside radar thingys they have around here, it (the GPS) almost always matches
tjkj2002 09-28-2013 08:33 PM
I just reach down in my center console and either hit the "UP" or "Down" buttons to adjust my speedo to match my GPS while I'm driving.
Goldenknob 09-28-2013 09:39 PM
could you better explain how you do that?
tjkj2002 09-28-2013 10:01 PM
You can't since you have ABS(not safely) and I went back to mechanical speedo drive with a electric interface to operate the OEM speedo and ODO.
Radcrd 09-30-2013 07:27 AM
They are all off, even my previous Liberty was off. Run bigger size tires to compensate next time you change tires. Based on my calculations you would need to be around 30.5'' Diameter to read close to accurate. Stock is 29.5'' Diameter.
tibo4wd 10-03-2013 10:08 AM
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd, like diesel much? ;)
Radcrd 10-03-2013 12:02 PM
3 VW TDI's (sold)
Just a bit addicted :D
Walt 10-04-2013 03:31 PM
Any ideas?
My speedometer reading is several mph different than the DashDAQ XL GPS mph reading. At highway speeds, the speedometer is 1-3 mph higher than the GPS. It reads 70 mph and the GPS reads 67-68 mph. When I get the GPS to read 70 mph, the speedometer reads ~73 mph. Less difference at lower speeds.
[Tires are new and stock size. Inflation at 35 psig. Alignment is good.] As the tires approach end-of-life and the tread wear indicators show, there will be a smaller tire rolling diameter and the indicated speedometer reading will be higher than actual, but not much..........
I believe the speed signal from the WK 545RFE xmission is electrical, not mechanical. To change its input to the dash module, it would take a device with re-programming capability. DashDAQ XL doesn't have that (as far as I know).
That's my story & I'm sticking to it...:)
The time now is 11:05 PM.
