Speaker Harness? - JeepForum.com
post #1 of 7 Old 11-17-2013, 05:38 PM Thread Starter
punisher65
punisher65's Avatar
2006 WK
Speaker Harness?
I just got some of the kicker upgrade speakers because the (what I thought were) stock speakers were blown out and I wanted something that would work and was plug and play. Turns out someone had already replaced them and cut off the factory harness. The kicker upgrade speakers use a harness plug, not the normal spade connectors. Does anyone know where I could buy more of the male harnesses (plugs in to the speaker)? Metra seems to only have adapters that go from the stock harness (wires) to spade connectors (speaker).
I guess my other option is just got pick up a component set from somewhere and call it good since some previous owner already butchered the wiring
2006 5.7 WK
OME HD, 265/70-17 Duratracs on Level 8 Strike 5, Aspen Creek Shackle Mounts,
Airaid CAI, Superchips Flashpaq, Gibson 3" catback, Steel Armadillo Engine Skid Plate
BT Catch Can, TB ground, Cree LED Reverse Lights, Interior LED upgrade
1993 4.0 ZJ
BB and 31" Bighorns SOLD :(
punisher65 is offline
post #2 of 7 Old 11-18-2013, 07:18 AM
RUGLAYR
My best guess would be to check a junk yard. You could also solder the wires directly to the speaker leads which will work fine if you have to.
RUGLAYR is offline
post #3 of 7 Old 11-18-2013, 02:04 PM Thread Starter
punisher65
punisher65's Avatar
2006 WK
The junkyard is a good idea. I hope I can find one around here with a WK.
As for the soldering, are you talking about the leads that are inside the connector?
2006 5.7 WK
1993 4.0 ZJ
post #4 of 7 Old 11-18-2013, 02:40 PM
Jeepforthewin
2010 JK Wrangler
If the junkyard doesn't work give clutchfield a call and ask them if they sell them
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #5 of 7 Old 11-18-2013, 02:49 PM Thread Starter
punisher65
punisher65's Avatar
2006 WK
I couldn't find any on their site besides the ones I listed in the original post
2006 5.7 WK
1993 4.0 ZJ
post #6 of 7 Old 11-18-2013, 03:09 PM
RUGLAYR
Easiest and cheapest solution if your ok with a solder iron. Solder your wires to one of these two places which could differ on your speakers
RUGLAYR is offline
post #7 of 7 Old 11-18-2013, 05:33 PM Thread Starter
punisher65
punisher65's Avatar
2006 WK
That'll work! Thanks!
Any idea which side goes where? I can still see the original wires. Guess I'll try to track down a picture or a wiring diagram or something.
Here is what mine look like:
2006 5.7 WK
1993 4.0 ZJ
