Quantcast spark plugs (3.7L) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > spark plugs (3.7L)
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 03-06-2010, 01:33 PM   #1
urezki
2005 WK
spark plugs (3.7L)
Hello folk,
I am to change spark plugs on my Jeep (2005 Laredo 3.7L). I am confused about which spark plugs i should use.
According to the spec, i should use Mopar SPZFR6F11G plugs (Resistor Copper Plug). But i was not able to find them, instead i bought Autolite AP5224 they are platinum ones.
My questions are:
Is Autolite AP5224 appropriate for my engine ?
Does anyone use them ?
What are the best plugs for my engine ?
Thank you.
urezki is offline   Reply With Quote
Old 03-06-2010, 05:50 PM   #2
lwg8tr01
I put in some Bosch double platinums about 2k miles ago and they work just fine. I don't think the 3.7L is as picky when it comes to plugs as the Hemi which needs the copper plugs. There are tons of threads here about what plugs to use, which is better, lots of anecdotal stories about stories of stalling, performance degradation, mileage drop off but they all seem to be non 3.7L specific. Me personally, I get a smoother idle and a about 2 more MPG in the city.
lwg8tr01 is offline   Reply With Quote
Old 03-06-2010, 07:48 PM   #3
tjkj2002
2002 KJ Liberty
Been running the Autolite double platinums for since 20,000miles(have 70,000 now) in my 3.7 and they work great in the 3.7.Though I do change them every year regardless of miles put on them.
tjkj2002 is offline   Reply With Quote
Old 03-07-2010, 04:34 AM   #4
urezki
2005 WK
Hm, i looked through this forum finding out this question, but found a lot of meanings, one people say
NGK is the best, other one say Champion and NGK is a crap.
Ok, i will go with Autolite and will see.
Old 03-10-2010, 09:49 AM   #5
08WKJGC
2008 WK
Im using the Bosch planinum plugs as well, no issues at all.
2008 Jeep Grand Cherokee Laredo 4x4 | 3.7L V6 | Stone White
08WKJGC is offline   Reply With Quote
Old 03-10-2010, 10:24 AM   #6
lwg8tr01
I don't know where this thought that you need to replace the spark plugs with the OEM ones got started. The ECM will adjust to just about any spark plug. I think it confuses peole when they see the "recommended" OEM replacement and mechanically what will work just fine. If you read further MOPAR recommends their own brand of air filter also, does that mean a K&N would'nt work optimally...silly huh? I think it's just an excuse to bicker on the internet.
Old 03-10-2010, 11:57 AM   #7
maxst2
2006 WK
Not true. Its been proven that platinum plugs don't work as well in some applications... I.E. they swapped to copper and rough idle and performance was sorted. Copper is superior in electrical conduction compared to platinum, but doesn't last as long... platinum does last longer...but with less conduction.
They make it OEM for a reason...because its designed to use X part.
maxst2 is offline   Reply With Quote
Old 03-10-2010, 12:56 PM   #8
Kaliber35
I just dropped some NGK platinum cores and have no complaints so far. I have actually even noticed an increase engine performance.
Kaliber35 is offline   Reply With Quote
Old 03-13-2010, 08:18 PM   #9
OGRC10T
I agree with you. OEM is there for a reason. I have noticed that different plugs work better in some applications than others. Platnum does last longer, but are not always the best to use for every application.
OGRC10T is offline   Reply With Quote
Glock Forum
