spare tire size difference - JeepForum.com
post #1 of 12 Old 05-12-2014, 07:24 AM Thread Starter
Hendrix9
2007 WK
Hey guys, quick question for you. How picky is quadradrive 2 about small tire size differences between the other 3?
My spare tire is practically new and the rest are almost at end of life. (stock forteras) One has started to get a slow leak(and I can't seem to figure out from where) so I was thinking about just throwing the spare on until I get new tires in a couple weeks. Would that create any issues?
Thanks.
2007 CRD QDII
2010 Jetta Sportwagen TDI 6MT - hoping it gets bought back!
2004 QD 4.7 GC
2009 Rav4 v6
Hendrix9 is online now
post #2 of 12 Old 05-12-2014, 07:40 AM
caulk04
2008 WK
I've been seeing 1/4" and even 1/8" difference mentioned here by reasonable good sources.
I'd recommend getting 5 new tires and keeping the spare rotated in so they always have the same tread life. This holds especially true for me since I went up to 255/60-18...
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 12 Old 05-12-2014, 09:03 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ While I'm not disputing what you've mentioned regarding slight differences causing issues, I have a hard time believing that mismatched tread depth on Forteras is gonna jack the system up.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 12 Old 05-12-2014, 11:28 AM Thread Starter
Hendrix9
2007 WK
I've procrastinated getting a lift, and i have 4 265/75/17s sitting here(lightly used and i need another used for a spare), so i'm really just trying to get by until i can fit the 265/75s. I guess i'll try it and hope for the best, or leave a small compressor full in the back just in case... Lol
2007 CRD QDII
2004 QD 4.7 GC
2009 Rav4 v6
post #5 of 12 Old 05-13-2014, 02:03 PM
10Xk
2014 WK
Subaru states that if you need to replace one tire that all 4 must be replaced due to the AWD system. Just something to think about.
10Xk is offline
post #6 of 12 Old 05-14-2014, 07:30 AM
koj
2010 WK
I run 265/70x17 and have kept my OEM spare. When using the spare I simply disconnect 1 ABS sensor which disables all differential lock up, ABS system. I then avoid low. Seems to work fine so far.
WH 2010 CRD. Bilstein shocks, Rustys 2" BB front, OME HD springs rear. 265/70x17
koj is offline
post #7 of 12 Old 05-14-2014, 08:43 AM Thread Starter
Hendrix9
2007 WK
I was wondering if there was a way to disable that. I'll remember that. I'm going to keep limping my slow leak tire around. My spare tire's valvestem was broken but I got that fixed this morning, so at least I even have a spare now... That woulda really pissed me off on the side of the road.
I figure if worst case I'll run the new-ish spare tire at a lower tire pressure to try to get it closer to the diameter of the others. That and maybe disconnect an ABS sensor like you suggested.
2007 CRD QDII
2004 QD 4.7 GC
2009 Rav4 v6
post #8 of 12 Old 07-10-2014, 12:56 PM
jeepinmoe
2008 WK
Where do I disconnect that? Thanks for any info.
jeepinmoe is offline
post #9 of 12 Old 07-10-2014, 01:44 PM
japeart
2007 WK
You should just be able to hit the ESP button and turn it off. That's i've done in the past.
Put a hole in the side wall of a bfg all terrian. stock size, about 3 months old with around 10000 km on it. when i put the stock spare forterra on, the size difference cause the ESP to go nuts and turn itself off. so i just turned it off whenever i drove the jeep til new tires came in.
since my tires were pretty new i just replaced the two rears and used the 5th tire for my new spare. the esp didnt have any issue with front and rear slightly different size.
07 Grand Cherokee - 3.0L CRD - GDE Hot Tune - QDII - OME HD - 255/75/17 BFG MT
Black WK Club #156
japeart is offline
post #10 of 12 Old 07-11-2014, 01:57 AM
koj
2010 WK
The sensors are located at each wheel and have a connector in the wheelwells. The easiest to get at is in the left fron wheelwell. Just turn the front wheels fully and disconnect the ca le
koj is offline
post #11 of 12 Old 07-11-2014, 04:38 PM
danb303
I've wondered the same. I bought a set of used rubicon pull offs that have different tread depths. 2 are 40% and 2 are 60% and the spare is still new. I have an OME ordered and if the rest of it ever comes in I plan on running the 2 60% tires I'm the back.
2006 Rubicon Unlimited Auto. 35" tires, 538 gears, Speedhealer, IRO 4"lift. Xenon flares
danb303 is offline
post #12 of 12 Old 07-12-2014, 12:27 AM
modernblueWK
If you have QD2 then you have mechanicsl limited slip in the diffs. Odd tire size may be an issue for the diff.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
