Spacer question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Spacer question
JKS Flex Connect in Actions!CCOR is Hiring! Athens, GA!ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 08-07-2015, 06:47 PM   #1
Toxic94
Spacer question
I ordered an RC 2" lift. What size spacers do you guys typically run?
My Build http://www.jeepforum.com/forum/f22/project-yj-learning-go-2366769/
Toxic94 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2015, 06:50 PM   #2
imthehink
2005 WK
What wheels/tires are you running?
imthehink is offline   Reply With Quote Quick reply to this message
Unread 08-07-2015, 08:15 PM   #3
Toxic94
Yeah should have specified. Stock wheels, 265/70/17 Kenda klevers
Unread 08-07-2015, 09:00 PM   #4
DuncsWK
2006 XK Commander
I ran 1.25" with 265/70/17 BFG M/T on Moabs with my WK
I'm running 1.5" 265/70/17 BGF KO2's on stock wheels with my XK
2014 KL Trailhawk - RRO Sliders, 27 MPG - Done
2006 XK Limited HEMI QD-II - Lift, T/A KO2, Rack w/LED - In Progress
2008 WK Limited HEMI QT-II - Sold
DuncsWK is offline   Reply With Quote Quick reply to this message
Unread 08-07-2015, 09:09 PM   #5
Toxic94
Originally Posted by DuncsWK
I ran 1.25" with 265/70/17 BFG M/T on Moabs with my WK I'm running 1.5" 265/70/17 BGF KO2's on stock wheels with my XK
how were the 1.25" ones?
Unread 08-07-2015, 09:29 PM   #6
DuncsWK
2006 XK Commander
They worked just fine. I still had to do the pinch weld mod, and the rear fender mod. You would have to do that with either size though.
Unfortunately, I don't remember where I found them, or what brand they where.
I'm running Spidertrax 1.5" on my XK, they don't have a 1.25"...
Unread 08-08-2015, 12:52 PM   #7
Toxic94
I think I'll get the 1.5" just a
For a little bit wider stance
Unread 08-08-2015, 02:06 PM   #8
xeasternskies
2007 WK
I'm running 1.5" Spidertrax on JK Moabs, never had any issues.
07 WK 4.7L V8 Limited l Flowmaster 44 l Spidertrax 1.5" l JK Moab's l Black WK #137.
xeasternskies is offline   Reply With Quote Quick reply to this message
Unread 08-10-2015, 02:00 PM   #9
Toxic94
any pics??
Unread 08-10-2015, 02:05 PM   #10
kwikrnu
2007 WK
1"
2007 WK CRD QDII,OME / bilstein 5100 lift,K&N intake,GDE hot tune,hidden winch mount Warn vr12000.
kwikrnu is offline   Reply With Quote Quick reply to this message
Unread 08-11-2015, 02:47 PM   #11
bersh
2008 WK
Actually, they do have 1.25", as I have a set. I think they are for the WJ, not sure. I have been mulling selling my 1.25" and getting a set of 1" from BORA. The problem with the 1" is I think the studs will be poking through. Not a big deal with stock wheels, but will hose me if I ever need the spare.
bersh is offline   Reply With Quote Quick reply to this message
Unread 08-11-2015, 07:13 PM   #12
billhofe128
2007 WK
im running rough country 2 inch with 265/65/18 sahara wheels on duratracs,, with 2 inch spidertrax,, had to do pinchweld and grind down pass side plate on frame,, though i didnt have to do the rear fenders, honestly dont see the point in that ,
billhofe128 is offline   Reply With Quote Quick reply to this message
Unread 08-11-2015, 08:39 PM   #13
mdimmick
2005 WK
The 1.25 Spidertrax spacers are listed for a WJ but work great on a WK as well. Part number is WHS-006
I just wanted a bit more fender coverage for the tire and slightly less bloated (best description I can think of) look from the back. Hence went with the 1.25 instead of 1.5
Most people won't notice a difference either way.
mdimmick is offline   Reply With Quote Quick reply to this message
Unread 08-12-2015, 09:25 AM   #14
finrisk
2005 WK
1,5" with 17" JK rims and 265/65 x 17 Firestone Destination A/T's with OME medium suspension. Looks and works awesome.
2005 Jeep Grand Cherokee 5.7 Hemi Ltd - Standard (except 255/65x17 Michelin A/S tyres)
2001 Jeep Grand Cherokee 4.7 Ltd 4x4 - Wife's (Sold)
finrisk is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 11:39 AM   #15
Hi-Lander
I run a 1.25" Spider Tracs on a XK with a RC2", and Monroe Load Levelers in the Rear. Running 2015 Rubicon Rims and 255/75/17. No rubbing. I tried the 1.5" spacers and even though only .25" per side they looked like they stuck out to far. The wider stance did make a difference in handling at speeds above 45mph.
Hi-Lander is offline   Reply With Quote Quick reply to this message
