spacer lift vs lift kit? - Page 2 - JeepForum.com
post #16 of 34 Old 09-19-2013, 04:02 PM
sk1er18
2007 XK Commander
Flyboys, cancel the order for the RC lift, set the front 5100s at 2" lift, order OME 2" lift springs in the rear with the money saved from cancelling the RC lift and call it a day.
...OK the OME springs will cost about $30-$40 more than the RC lift... not a big deal.
-Matt
sk1er18 is offline
post #17 of 34 Old 09-19-2013, 04:12 PM
Flyboys
2015 JK Wrangler
Well Im going on Kolak's recommendation 90% street driven WK limited Hemi
46,000 miles, New adjustable Bilstein front, Bilstein 5100 rear, RC 2" spacer lift (use factory springs). will be running 2013 18" Sahara rims tires.
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #18 of 34 Old 09-19-2013, 04:15 PM
sk1er18
2007 XK Commander
Your rear is going to sag with that setup.
-Matt
sk1er18 is offline
post #19 of 34 Old 09-19-2013, 04:20 PM
Flyboys
2015 JK Wrangler
Not the impression I got form the recommendation. Thanks for the heads up.s
I guess I'll see next Wednesday thats when It all gets installed
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #20 of 34 Old 09-19-2013, 04:24 PM
sk1er18
2007 XK Commander
Roger that. If it sags too much for your liking I actually have a set of rear OME HD springs i could sell (i swapped them with superlift springs). I'm about 45 minutes away from Cherry Hill so just shoot me a PM if you think you'll need them.
-Matt
sk1er18 is offline
post #21 of 34 Old 09-19-2013, 04:33 PM
ca07wk
2007 WK
Yes and get the MD coils so there isn't a huge difference in spring rate
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #22 of 34 Old 09-19-2013, 04:36 PM
ca07wk
2007 WK
You can get the rustys rear coil spacer and use that in place of the lower rear coil isolator, it will give you about 1" of rear lift. You don't want stock coils up front and OME HD in the rear, its to big a difference in spring rate.
ca07wk is offline
post #23 of 34 Old 09-19-2013, 06:48 PM Thread Starter
wicat3
2005 WK
If I went OME and needed new bolts is there a place to get them or tractor supply grade 8?
wicat3 is offline
post #24 of 34 Old 09-20-2013, 10:29 AM
overland-wk
2006 WK
Y is everyone stuck on ome springs? Im just curious am i missing something?
06 ROR lifted wk (mine)
07 RC lifted xk (wife's)
Youtube channel
Bumsmodified98xj
overland-wk is offline
post #25 of 34 Old 09-20-2013, 10:52 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Because there is good, better, best - OME being the last of those 3.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #26 of 34 Old 09-20-2013, 11:06 AM
overland-wk
2006 WK
OME made in australia? I'd rather spend my hard earned money on an american made lift kit. Imo
Youtube channel
Bumsmodified98xj
post #27 of 34 Old 09-20-2013, 11:34 AM
JeepN4KC
JeepN4KC's Avatar
OK, understandable, good luck with that.
~Mike~
WK
XJ
JeepN4KC is offline
post #28 of 34 Old 09-20-2013, 02:48 PM
Jeepforthewin
2010 JK Wrangler
Besides OME the only other suspension kits we have are the 4" superlift and JBA's highly priced lifts. There are other lifts out there but not many on the forums as most others are not that good. Hence why everyone says go OME cause of the quality.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #29 of 34 Old 09-20-2013, 03:05 PM
jjarvis0007
2005 WK
Will the OME MD work with my stock air bags that are inside my rear coils?
jjarvis0007 is offline
post #30 of 34 Old 09-20-2013, 03:11 PM Thread Starter
wicat3
2005 WK
How much of a ride difference would you get with a RC spacer lift compared to stock?
wicat3 is offline
