spacer lift vs lift kit? - JeepForum.com
post #1 of 34 Old 09-19-2013, 05:38 AM Thread Starter
wicat3
2005 WK
Hey guys this may be a stupid question or maybe its been gone over before but I didn't see it. I was wondering whats the difference between a spacer lift, such as like a rough country lift which I heard referred to as this, and a lift kit, such as an ome lift? Im looking to get a little lift in my 05 WK and I don't do much offroad maybe a few times a year but I love the look.
wicat3 is offline
post #2 of 34 Old 09-19-2013, 05:56 AM
Jeepforthewin
2010 JK Wrangler
The difference is how the lift is achieved. The Rough Country lift is a spacer lift which basically is putting a 2 inch peice of metal on top of your front and rear coils to achieve the 2 inches of lift. Out of all the spacer lifts I would say the Rough Country is the best due to all metal parts instead of using poly spacers. A suspension lift on the other hand achieves the lift by using longer front/rear coils and also new shocks and struts. You will get the best ride and feel from a suspensions lift but it will cost more.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 34 Old 09-19-2013, 10:28 AM
camber
If you are only looking to offroad a few times a year, I would go with the spacer lift. However, that is dependent on if your factory shock and struts are still in good shape. If your Jeep has more than 75k miles on it, I would suggest having them checked out. If you are needing to replace them anyways, then you might as well go with the Old Man Emu setup.
camber is offline
post #4 of 34 Old 09-19-2013, 10:36 AM
bhawks28
2014 JK Wrangler
It's pretty common for people to buy a spacer lift, love it, and then want to upgrade to the OME lift or Super lift. In my opinion, you might as well skip the spacer lift and save up for the OME lift.
2014 JKU Rubicon
bhawks28 is offline
post #5 of 34 Old 09-19-2013, 10:38 AM
816jared
2005 WK
I agree here. The difference in price between in a spacer type setup + new shocks/struts vs OME HD/MD is only a few hundo...
816jared is offline
post #6 of 34 Old 09-19-2013, 10:39 AM
Jeepforthewin
2010 JK Wrangler
I second this haha. I currently have the RC spacer lift and am now in the process of getting a 6" modified Superlift
post #7 of 34 Old 09-19-2013, 11:12 AM
DRCracker
2006 WK
I agree.
I had experience trying a spacer lift on an XJ, solid axles.
While it doesn't totally compare with the WK,
it did cause a good deal of axle wrap and other instability.
Save for the OME kit, you'll need new springs and shocks eventually anyway.
Replace the old worn out ones with new OME lifted ones
and you'll have no regrets.
My opinion.
TC
MOLON LABE: 2006 WK Limited, Dark Khaki Pearl, 5.7 HEMI, QDII,
Console XDs-45acp, Billet Catch Can, Airaid CAI Tube,
1" Spacers, Steel Armadillo Sliders, Dark Khaki 4xGuard Front Skid,
Dark Khaki 2011 #9104 Wheels, Firestone Destination A/T 265/70/17's.
OME HD lift. Dark Khaki Matrix Brush Guard, Dark Khaki Painted Headlight Bezels.
Hemi Club #65 // Khaki WK Club #40
DRCracker is offline
post #8 of 34 Old 09-19-2013, 12:59 PM
bhawks28
2014 JK Wrangler
You also get an upgrade in ride quality if you change suspension. I personally love the way my OME HD rides on and off road. Although, the HD might be a little stiff for some, so you can always get the MD.
2014 JKU Rubicon
bhawks28 is offline
post #9 of 34 Old 09-19-2013, 02:06 PM
helmetface
Just upgraded my rear leafs to OME HD, stock shackles, new bushings(derp) and sensatrac shocks(~2" over stock) and it rides like a dream and looks great too. I always have the option of bigger shackles and blocks for a few more inches.
helmetface is offline
post #10 of 34 Old 09-19-2013, 02:29 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
This is the WK side. Sounds like you have an XJ (or maybe a YJ).
Different platforms and suspension components.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #11 of 34 Old 09-19-2013, 02:29 PM
BoraBora
2015 JK Wrangler
^X2! I had the RC 2'' lift for about 2 months and right before I was planning on installing it...I already knew I wouldn't be satisfied and decided to dish out the money for the OME. I see you live up north, be prepared to also purchase new bolts and nuts for the suspension. Mine were so rusted, the shop I had it at wanted to replace the LCA's because the bolt was stuck Instead we just purchased new bolts, busings and nuts. Called it a day.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #12 of 34 Old 09-19-2013, 03:26 PM
Flyboys
2015 JK Wrangler
I was all set to go OME MD but ordered the RC 2" (spacer) with all new Bilstein 5100's on sale from Kolak. My truck only has 46000 miles on it so I figured i'd keep the springs for now and with good price on the shocks and the RC saves a few hundred and put that towards new wheels and tires. Other reason is most likely will get another truck in about 2 years thats when my vehicle ADD kicks in lol.
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #13 of 34 Old 09-19-2013, 04:12 PM
ca07wk
2007 WK
with the 5100's up front you will have alot of rear sag. Mine with the stock replacment bilsteins up front had some rear sag that I corrected with stacking coil isolators.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #14 of 34 Old 09-19-2013, 04:17 PM
Flyboys
2015 JK Wrangler
they are adjustable 5100's up front
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #15 of 34 Old 09-19-2013, 04:20 PM
ca07wk
2007 WK
They are but at the lowest setting they are .75" over stock, so you are lifting the front 2.75" and 2" in the rear, I think the rear of mine only lifted 1.75" with the RC spacers
ca07wk is offline
