Spacer lift has caused SEVERE noise in the rear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Spacer lift has caused SEVERE noise in the rear
RIGID LED Light Blowout Sale - All Sizes, All Series, all Jeep Wrangler Complete Gear Upgrade Kits with Installs andBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 09-22-2009, 09:06 AM   #1
crump582
2006 WK
I have the RRO spacer lift and am having some really annoying noise issues. I replaced the shocks with some better ones (the ones sent sucked), but that hasn't stopped the rattle noise. I can sit in my WK and shake it back and forth and it rattles like crazy. I don't know what to do. I can't find exactly where it's coming from. It's in the back, but not sure exactly where. Anybody have a suggestion, or similar experience?
I'm going crazy...
[B][SIZE="2"][B][FONT="Fixedsys"]2006 WK Laredo
Rocky Road 2.5 Lift
BFG T/A 265/70R17
American Racing XD Addicts, 17x9
Rola Roof Rack[/FONT][/B][/SIZE][/B]
[B][SIZE="3"][FONT="Fixedsys"]eat, drink, and be merry... for tomorrow, we die.[/FONT][/SIZE][/B]
crump582 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2009, 04:02 PM   #2
WSPJeep
Welcome to the world of polyurethane spacers.
Matt
'90 YJ- 4 bangin on 32's
'72 Dodge Dart 318 V8, 2 door
WSPJeep is offline   Reply With Quote Quick reply to this message
Unread 09-22-2009, 04:23 PM   #3
nostaw22
What do you mean by "shake it back and forth"?
Check all the bolts on the suspension to be sure they're tight and haven't loosened up.
Poly spacers may also transmit noise/vibes.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2009, 04:59 PM   #4
TRZ
2008 WK
Poly Spacers are less than ideal on a unibody but aren't going to cause rattling.
If you can re-create the problem by rocking the WK in your driveway, then get someone to rock it while you get underneath and search for the source.
TRZ is offline   Reply With Quote Quick reply to this message
Unread 09-22-2009, 06:20 PM   #5
onlyone
2014 JK Wrangler
Check to see if the driver side control arm is hitting the gas tank skid. That's probably no it, but worth a shot.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline   Reply With Quote Quick reply to this message
Unread 09-23-2009, 06:01 AM   #6
Dreezy
1990 FSJ Wagoneer
I would check your sway bar links.
Dreezy is offline   Reply With Quote Quick reply to this message
Unread 09-23-2009, 06:11 AM   #7
crump582
2006 WK
It does it on both sides... and I've had it back to the shop that installed it to have everything checked again. Nothing seems to be loose.
If it's the sway bar links, would it be caused by the lift? What should I replace them with?
Rocky Road 2.5 Lift
BFG T/A 265/70R17
Unread 09-23-2009, 09:29 AM   #8
Dreezy
1990 FSJ Wagoneer
I was thinking more along the lines of loose bolts. If it makes noise when you rock it side to side that would be my first thought. Lay on the ground underneath and have a friend rock it back and forth. Follow the sound and touch different things as its making th noise. Whatever it is will vibrate.
Unread 09-24-2009, 05:13 AM   #9
koj
2010 WK
On my CRD the panhard bar was touching the axle bracket. It was barely visible. I had to cut off material on the bracket to clear the bar.The engine protective plate was also loose and making a rattling noise.
koj is offline   Reply With Quote Quick reply to this message
Unread 07-16-2014, 09:23 AM   #10
ISUzj
2005 WK
I have had a steel spacer lift for a few weeks. I have had an annoying rattle in the back. I put washers b/t by shock ends and there is a rattle that only seems to happen when the jeep shakes laterally.
I cant replicate the rattle when its parked, it has a sound similar to a hitch rattling in a receiver (which I dont have)
Thoughts?
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
My Build Thread Align your jeep yourself B N B#175
ISUzj is offline   Reply With Quote Quick reply to this message
Unread 07-16-2014, 09:29 AM   #11
luckyse7ens
2010 XK Commander
Torque down everything again?
Black WK Club #152
luckyse7ens is offline   Reply With Quote Quick reply to this message
Unread 07-16-2014, 09:36 AM   #12
paroxysym
2007 WK
check your shocks again... check your swaybar bushings and links as well.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote Quick reply to this message
Unread 07-16-2014, 09:41 AM   #13
nostaw22
I didn't think of it before, but our WK developed a rattle after I installed new rear shocks. I've never spent time determining why though (wife drives the WK and doesn't complain about it). It was a simple job to unbolt the old ones and install the new ones.
JW
Unread 07-16-2014, 10:22 AM   #14
luckyse7ens
2010 XK Commander
Last set of shocks I installed rattled a lot. I forgot to tighten one of the shock mounts all the way down.
Sometimes you will need washers and grease to keep them from rattling, had that issue with a friends truck.
Black WK Club #152
