Something Doesn't add up... CRD QD-II? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Something Doesn't add up... CRD QD-II?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 08-17-2015, 11:32 AM   #1
Peace
2008 WK
I'm looking at getting this Jeep and I was hoping for the QD-II setup. From what I have read it would have the Quadra-Drive badge in the center console and a 12 bolt rear end (both of which this one doesn't have). Everything leads me to believe that this Jeep has the Quadra-Trac system.
So I called Jeep and had them pull a build sheet on the VIN and it shows up that it has a QD-II setup. Is there something fishy going on here? (Swapped VIN?) or could the Build Sheet be wrong?
http://www.cars.com/vehicledetail/de...1415/overview/
EDIT: I had them fax me over the build sheet. It shows Quadra-Trac II. Nothing weird going on here.
Peace is offline   Reply With Quote Quick reply to this message
Unread 08-17-2015, 12:14 PM   #2
caulk04
2008 WK
Mystery solved. Cool post
Spare is in the wrong way...
For sale: http://www.jeepforum.com/forum/f125/08-overland-wheels-tires-tpms-3581914/
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 08-17-2015, 12:33 PM   #3
Peace
2008 WK
Yeah kind of a pointless post now. Whoops. Mod can delete it if they want.
I'll make sure to fix that.
Unread 08-17-2015, 12:41 PM   #4
colinzj
2006 WK
If by "wrong" you mean "far more convenient".
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline   Reply With Quote Quick reply to this message
Unread 08-17-2015, 12:51 PM   #5
jd0110
2007 WK
should be mounted in spare location wheel side up vs down. This to protect the nice side of the wheel from road grime.
2007 CRD QDII, OME HD, JK AEV Pintlers, 265/70/17 BFG KO2, 4xG Matrix, belly, RockRails, GDE ECO/HOT, UCF DIff, JBA Disco's
jd0110 is offline   Reply With Quote Quick reply to this message
Unread 08-17-2015, 01:34 PM   #6
caulk04
2008 WK
I see it mostly as a measure to avoid flling the wheel up with road crap. It's still going to get nailed with salt and corrode, but at least it won't be full of dirt and off balance.
Unread 08-17-2015, 08:30 PM   #7
modernblueWK
QT2 is still a very good system. Has never let me down.
SOLD 2008 WK 4.7 V8 Build/Adventure Thread
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline   Reply With Quote Quick reply to this message
