Solution for those having problem with HID - JeepForum.com
post #1 of 1 Old 02-24-2008, 02:11 PM Thread Starter
bull_blaster
2005 WK
hello guys...
This post is to help the folks who have been dealing with HID STROBING on their WK. The solution is very simple. basically, you could either go with relays or go with a new method that im about to share with you guys.
Here is what i did:
I installed a 10000 uF 25V Capictor in parallel between the Pos and Neg of the supply line right before the ballast and placed 10 amp fuse on the Pos before the ballast
here is a snap:
***CAUTION*** : Always use eyes proctection when working with capacitors, also note that capacitors are polarized, the positive need to go with positive, negative with negative, other wise there is a big risk you might blow the capacitor.
bull_blaster is offline
Need Cheaper Solution To A New Key... 01Limited45324 ZJ Grand Cherokee Forum 16 04-29-2009 01:48 PM
04 Fog Alternative Solution!! NewbombzWJ ZJ Grand Cherokee Forum 16 11-08-2008 12:50 AM
WK Hemi Exhaust Solution? Rappelsack WK Grand Cherokee & XK Commander Forum 4 04-03-2008 10:39 AM
Found the Problem, what's a solution? redhatman ZJ Grand Cherokee Forum 10 01-04-2008 06:39 AM
LONG STARTING PROBLEM - SOLUTION<<Sticky it please>> RTst ZJ Grand Cherokee Forum 3 10-09-2006 01:55 AM
