So who wants to help me solve my wet idle surge issue? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > So who wants to help me solve my wet idle surge issue?
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-12-2015, 09:34 PM   #1
Jeff1119
2009 WK
Im starting a new thread on this issue ,since the old thread is just about dead, in hopes someone wants to help me and put up with the issue I'm having. Basically to sum it up real quick, my 09 jeep grand cherokee runs great in dry weather but when it rains the idle will surge. Its something I've put up with for 6 months now. It just really annoys me because i love my jeep but this stupid wet electrical issue is pissing me off to the point that i want to trade it in. Now that its starting to warm up I plan on spraying the bottom of the jeep with a hose and seeing if it will do it. Ive come down to the conclusion that it has to be something on the bottom of the jeep thats getting wet thats electrical and is causing this. Ive changed the 3 coils and spark plug wires so i know thats not it. I can't see how also it would be something on top of the engine electrical because its so hot that i don't see how moisture or rain could effect it long enough. When the rain stops and the roads dry up, i have to drive around for a little before it will stop surging so that whatever is wet causing this issue can dry out in which it can stop surging. So that leads me to believe its something on the bottom of the jeep getting wet if i have to drive around when the rain has dried up for it to stop.
If you wanna see my problem in more detail, look under my post "does anyone else jeep do this" to see what i have tried. I really love this jeep. Its a great car when its dry out and has been reliable. But this stupid water issue with the idle surging like its about to stall makes me want to just get rid of it. I know some people are tired of hearing me complain about this but theres got to be a way to find the problem and fix it even if theres no codes. Mechanic is out of the question because trust me, I've been there and tried that, they are clueless. I even went on justanswer.com to ask 37 year experienced jeep mechanic who doesn't even know where to start. Like really? there has got to be a dam solution. Anyways, please chime in if you can offer some solutions and i would appreciate it
Jeff1119 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 02:21 AM   #2
RCS1300
2005 WK
I did not read your other thread.
Do you have diagnostic tools and experience in using them? Scanner, node lights, spark plug light, fuel pressure gauge, and propane?
Spark, air, fuel. If it were my jeep I would first check for codes, then my O2 sensor readings for rich conditions that may indicate a vacuum leak, then node lights to make sure my injectors are getting spark, then a spark plug light to make sure my plugs are getting power, then test my idle air control valve to make sure it is not sticking. I would also check my fuel pressure to make sure it is up to spec and possibly the injectors to make sure they all are working correctly.
Or, find a good independent mechanic that can do this for you.
You did not mention whether there are misfires. If no misfires it is still possible but less likely that it is an electrical problem.
Edit Add: I read the first post on your other thread. Looks like you have thrown a lot of new parts into the Jeep trying to solve the problem. Based on the idle issue mentioned in that post I would first test each injector to make sure they are working correctly. It takes a scanner, fuel pressure gauge, and some experience. It could be a few of your injectors are not allowing enough fuel to pass sometimes at idle. Still, the diagnostics mentioned above are highly recommended.
I need to do the same test on my Jeep when the weather warms up a little more.
RCS1300 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 03:38 AM   #3
Greever
2008 WK
when was the last time you did a transmission oil change? and have you triple checked that open connector that you found and made sure its still wraped up tight?
2008 4.7 V8 Limited
Greever is online now   Reply With Quote Quick reply to this message
Unread 03-13-2015, 06:24 AM   #4
RCS1300
2005 WK
Yes, it could be this simple. How many miles on the jeep, how many owners, how long have you had it?
Could also be simple things like spark plug wires too old or connection at the pcm between pcm and injector or coil wires is corroding. However, this kind of a problem should trigger misfires but not always.
Unread 03-13-2015, 09:09 AM   #5
Jeff1119
2009 WK
In response to both, the spark plug wires have been changed. I have not changed the transmission fluid yet. Also that connector is still wrapped up tight but that wasn't the issue. Now if your talking fuel injectors and misfires, I don't have any misfires. But if the fuel injectors weren't working correctly wouldn't this happen on a dry day too? I've used fuel injector cleaner many times. Again it's making me believe something is getting wet that is not suppose to be. I have used the scanner before to look at the readings for the sensors. O2 sensors are within range as well as the tps is. I did notice that when it rains water from the cowl drips on the pcm wires through a little passage so I'm not sure if that's causing it. I haven't actually sprayed them with a spray bottle
Unread 03-13-2015, 09:13 AM   #6
Jeff1119
2009 WK
Also it has 40,000 miles on it. Had 1 owner before me and had it for a year. Also the best example I can give you of how it acts when it's raining is taking the brake booster hose off the brake booster and pouring in sea foam as the engine catches itself
Unread 03-13-2015, 09:57 AM   #7
RCS1300
2005 WK
Find out which connector has the injector signal pass through it. I would check that connector for corrosion. Should be visible to the eye. For the 6 cylinder engine I believe it is connector C1 and C2.
Also, fix the cowl drip ASAP.
Unread 03-13-2015, 10:43 AM   #8
Jeff1119
2009 WK
ok these connectors are on the top of the engine under the fuel rail right?
Unread 03-13-2015, 11:36 AM   #9
Jeff1119
2009 WK
This is what I'm talking about when it rains, you can see how the water drips through that corner onto the pcm connections
Unread 03-13-2015, 11:49 AM   #10
DavidsCyclops
Jeepaholic
DavidsCyclops's Avatar
2014 WK
No, the connectors he is talking about are the ones in the picture you posted.
DavidsCyclops is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 11:52 AM   #11
DavidsCyclops
Jeepaholic
2014 WK
The connector closest to the front of the car, is connector C1, if you have an 8 cylinder engine, the connections for fuel injectors #7 and #8 are in that connector as well are the connections for #7 and #8 coils.
The middle connector, is connector C2. It has the connections for the first 6 injectors on the engine. As well as the the connections for the coils for the first 6 cylinders of the engine.
Unread 03-13-2015, 12:31 PM   #12
Jeff1119
2009 WK
Gotcha. I have removed these connections before and did not see any corrosion inside of them. However, I did not spray contact cleaner or put dielectric grease on them. Would that be a good idea?
P.s. Put silicone in the area the drip was coming from just now
Unread 03-13-2015, 02:40 PM   #13
RCS1300
2005 WK
Tomorrow will be a good test of the silicone seal!
Unread 03-13-2015, 03:23 PM   #14
Jeff1119
2009 WK
Well i had to remove it because apparently it was not doing anything to hold the water back. Water still found a way in not sure how. What i did do though is wrap the main connectors that water was dripping on with electrical tape a few times
Unread 03-15-2015, 11:02 AM   #15
RCS1300
2005 WK
Is the problem fixed?
