Smoke under hood - JeepForum.com
post #1 of 3 Old 09-24-2013, 10:12 AM Thread Starter
r_p
2005 WK
Smoke under hood
Hello
Bought a used WK (~75K miles) a few days back. Since then I have been noticing a weird smell and then yesterday I saw white smoke coming from under the hood.
The source of the smoke is the driver side. I am fairly sure its not the engine (clear exhaust, no leaking coolant etc.) or the heater core (no leaks inside AFAIK) or even a stuck caliper (dealer did work on brakes before selling the vehicle to me).
It appears that the smoke is come from the steering joint which is pretty close to the heat shield as shown in the picture or something below it. Any ideas as to what could be wrong? The steering does feel tight but then it is my first Jeep and I have nothing to compare too.
The vehicle did come with a short term dealer warranty so I will have it checked soon. Would it be safe to drive until then?
Here are two images that show the source of the smoke (the 2nd one is the close up view).
Thanks in advance.
r_p is offline
post #2 of 3 Old 10-21-2013, 10:15 AM
ggt1_02
2009 WK
I saw this post when I was looking for a solution to the same issue. My jeep will randomly emit white smoke from under the hood near the fire wall, usually while sitting at a traffic light. It is not always the same amount (my recent thought is that the amount of smoke coincides with an oil change more smoke after then tapering off). I have searched high and low thinking it was an electrical issue and have had it in to the dealership with no results they actually told me it was a piece of plastic road debris on the exhaust. While poking around late last week I noticed that the gasket on the valve cover has a leak on the lower right nut. The oil is leaking onto the exhaust directly below it. I hope this helps, I plan on calling the dealership to see if it is warrantied, if not it doesn't look to difficult to get to.
ggt1_02 is offline
post #3 of 3 Old 10-22-2013, 08:59 AM Thread Starter
r_p
2005 WK
Sorry for not following up. Yes it was the valve cover which had a small leak.
r_p is offline
