SmartBeam Survey - JeepForum.com
post #1 of 21 Old 10-05-2006, 02:36 PM Thread Starter
smartbeam
SmartBeam Survey
Does anyone use the SmartBeam feature by Gentex on the new Grand Cherokees (and other DCX vehicles)?
I am interested in how well this system works and if there are any complaints about it. If you use the system and feel that it works perfectly, please also comment that you are satisfied.
Thanks,
Steve
smartbeam is offline
post #2 of 21 Old 10-05-2006, 03:18 PM
Harts2k
Completely satisfied.
Harts2k is offline
post #3 of 21 Old 10-05-2006, 05:27 PM
LordGriNz
It works 'ok' but I dont like it when driving thru corners, it just doesnt work well
there. It would have been better to have the sensor turn when the car does so
that it would actually be looking in the direction of travel. Basically if it cant see
the other cars headlights then they wont click down to low beam.
LordGriNz is offline
post #4 of 21 Old 10-05-2006, 06:32 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
I agree with Lord and those windy road conditions are where you usually need the highbeams the most. Also I don't like that it turns off the fog lights when switching to highbeams. I know most DCX vehicles with factory fogs do that but it is annoying none the less.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #5 of 21 Old 10-05-2006, 11:45 PM
S2WOOOW
I don't use it for the same reason stated above.
S2WOOOW is offline
post #6 of 21 Old 10-06-2006, 02:06 AM
soldierguy
soldierguy's Avatar
I use it and love it. It's nice to have consistent visibility regardless of the ambient lighting conditions.
soldierguy
2012 Wrangler Rubicon 2-door
2009 Aprilia Dorsoduro 750
2008 MV Agusta Brutale 910S
soldierguy is offline
post #7 of 21 Old 10-10-2006, 08:52 AM
wkearney99
2006 WK
I've got in my WK and it's great. If you're on windy roads then it may be worth using just the low beam control of it. That way it'll still turn them off/on automagically under normal driving and leave you in control of the high beams.
But in the limited number of times I've driven it on windy roads I've found it's reasonably good at dipping the high beams as necessary. Bear in mind, it fades the lights, it's not just cutting them on/off. So it's probably a lot less annoying to the other drivers than you might think.
wkearney99 is offline
post #8 of 21 Old 10-10-2006, 01:11 PM
Podedwards
Podedwards's Avatar
Smart Beam
Thanks,
Steve
I have it on my 2006 Grand Cherokee-works great-no problems-love it!
Podedwards is offline
post #9 of 21 Old 10-12-2006, 11:28 AM Thread Starter
smartbeam
Thanks guys, this helps a lot... if anyone has anything to add please do... I'm trying to get a lot of opinions on the system.
post #10 of 21 Old 10-16-2006, 06:51 PM
JeepySteve
I Love It!
BTW, it's a law or DOT requirement that the fog lights shut off when high beams are in use.
2005 Limited 5.7L Maxed OUT!
JeepySteve is offline
post #11 of 21 Old 09-10-2007, 10:58 PM
Baron58
I have it on my 07 Commander. I was skeptical at first but it works very well, up until the system failed at 4 months since new. Still waiting for the dealer to fix it.
Baron58 is offline
post #12 of 21 Old 09-11-2007, 06:11 AM
07WKLtd
2007 WK
Use it, love it.
Just hate that the fogs go off.... oncoming drivers probably think we're idiots.
07WKLtd is offline
post #13 of 21 Old 09-11-2007, 08:00 AM
JWLJeep
Works correctly about 50% of the time. It typically changes in town on side streets or on one-way streets. I wish you could set the lights on automatic and turn the smartbeam feature off. I just don't really have a need for it as it's too unreliable. But, I want the headlights to be automatic.
John
2006 Jeep Grand Cherokee Limited with 5.7L Hemi in Bright Silver
Bloomington-Normal, IL
JWLJeep is offline
post #14 of 21 Old 09-11-2007, 12:26 PM
07WKLtd
2007 WK
You can. Leave the main headlight switch on auto, and disable smartbeam (called automatic high beams IIRC) in the EVIC
07WKLtd is offline
post #15 of 21 Old 09-11-2007, 04:08 PM
JWLJeep
I did that but it didn't seem to do anything! It's been quite a while so I will go back through that and try again.
John
JWLJeep is offline
Auto headlights and Smartbeam fault rolls101 WK Grand Cherokee & XK Commander Forum 12 06-17-2011 12:47 AM
can I swap out my rear view mirror and install the mirror with smartbeam uconnect? Jbripps WK Grand Cherokee & XK Commander Forum 12 03-11-2009 06:06 PM
smartbeam camera/ inspection sticker nhphoneguy WK Grand Cherokee & XK Commander Forum 5 05-12-2008 06:54 AM
Smartbeam problem after windshield replacement mckat WK Grand Cherokee & XK Commander Forum 5 02-08-2008 06:38 PM
JF Survey Keith WK Grand Cherokee & XK Commander Forum 0 10-01-2007 12:35 PM
