Sixfoot9psu's Build Thread - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Sixfoot9psu's Build Thread
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 03-20-2012, 12:03 AM   #31
blizzboy283
2005 WK
Originally Posted by Omelet
I had LED tails and revers lights and only needed resistors for the front once I installed the LEDs up there. Try a pair of 6ohm resistors and if that doesn't work try 3ohm.
I have 6 ohm ones that I'm going to install tomorrow. How did you mount them? I imagine they get pretty hot?
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2012, 01:00 AM   #32
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yes they get hot. I mounted mine on the inside lip of the engine compartment just aft of the headlights.
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 03-21-2012, 01:31 AM   #33
blizzboy283
2005 WK
I guess you wired in some longer wires?
Unread 03-21-2012, 09:33 AM   #34
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yes I extended the wires on each end to have plenty of wiggle room. Otherwise mounting locations are very limited.
See How It Was Made
Unread 03-23-2012, 02:40 PM   #35
blizzboy283
2005 WK
Originally Posted by sixfoot9psu
some 3157's won't fit through the hole in the headlight housing though, but the ones above in quotes do and work perfectly.
you don't need resistors but since they're LEDs they will blink twice as fast as the stock bulbs. wired as below EXCEPT THE POSITIVE SHOULD BE WIRED TO THE GREEN WIRE (I didn't take a pic after I fixed it
the resistors i got were sold by ebay seller ceresimports08 and titled "Load Resistor Fix LED Bulb Fast Flash Turn Signal Blink" and they are 6 ohm and come with the taps needed to wire them in
I can't get mine to work. Using your picture as the guide: do you wire them into the first and third wires? I did that and I can't get them to work.
Unread 03-24-2012, 11:49 AM   #36
sixfoot9psu
2005 WK
Yea I did first and third and it works fine...that's weird, maybe it's bc you have LEDs in the rear?
'05 GC 5.7L Hemi QDII...Rock Krawler lift, 4XGuard Matrix, rock sliders, front and rear skids, belly guard, rear diff guard, Bilstein HDs, Volant intake, 265/70 Goodyear DuraTracs, Superchips, Rola roof rack, BORA wheel spacers, Rocky Road Leveling Spacers, Magnaflow muffler, KC Slimlights, BT catch can, tb cover, and underhood kit, Expanded Sheet Metal Grille
[URL="http://www.jeepforum.com/forum/f67/sixfoot9psus-build-thread-1341203/"]Build Thread[/URL]
'09 G8 GT 6.0L...Kooks Headers, Rotofab intake, SLP exhaust, Vector Motorsports Tune
sixfoot9psu is offline   Reply With Quote Quick reply to this message
Unread 03-25-2012, 02:51 AM   #37
blizzboy283
2005 WK
I have led rears, license plate, and reverse lights. I'm upgrading to 3 ohm resistors as per Omelet's recommendation.
Unread 03-25-2012, 07:02 AM   #38
Rob 99TJ
Originally Posted by sixfoot9psu View Post
How it sits as of now:
How much lift did you get, front and rear, after the Bilsteins and strut plates???
Jeep looks great.
99' TJ Gunmetal Blue Sport /w D30 No-Slip/D44 Trac-Loc, 5spd, 2" susp./1" body, 33"MT/R's/AR767's, Durabak, Currie, Warn
07' WK Silver 5.7 QD2, Bilsteins & front strut plates.
Rob 99TJ is offline   Reply With Quote Quick reply to this message
Unread 03-25-2012, 06:47 PM   #39
sixfoot9psu
2005 WK
Jeep looks great.
Thanks!
from the bilsteins, strut plates, and new spring isolators I got 2" up front and .5" in the rear
Unread 03-29-2012, 08:01 AM   #40
Rob 99TJ
Thanks!
Do you think the spring isolators gave you any lift? I've read that the Bilsteins are good for 3/8" and the front strut plates about 1/2". Do you think that's about right?
Unread 03-29-2012, 12:45 PM   #41
sixfoot9psu
2005 WK
i think the spring isolators gave some lift since the old ones were completely worn...i took measurements everytime i did anything to it and the measurements didn't really make sense since the strut plates/bilsteins/isolators up front gave 2" lift and the isolators/bilsteins in the rear didn't do much at all (less than .5")
Unread 04-20-2012, 04:20 PM   #42
sixfoot9psu
2005 WK
installed my 4xguard rear guard 2 the other day...it didn't line up the way i wanted with either set of holes so i drilled my own holes exactly 1" from the one set of holes (center to center) as seen below:
Unread 05-10-2012, 02:44 PM   #43
sixfoot9psu
2005 WK
installed my 4xGuard Matrix a little while ago and finally took pics with my camera instead of my phone:
Unread 05-10-2012, 03:03 PM   #44
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Jeep's lookin good!
You mentioned new spring isolators - did you get them from JBA?
One on the top and bottom of the rear coils?
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 05-10-2012, 03:18 PM   #45
S1L3NT_WH33L3R
2005 WK
looks good man, real clean.
Idk about that rear guard...its shaped funny for my liking.
which gen is that one?
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline   Reply With Quote Quick reply to this message
