Shudder/Vibration while driving - JeepForum.com
post #1 of 6 Old 09-15-2014, 10:04 AM Thread Starter
eneusiis
2008 WK
Need some help diagnosing. This has happened twice now, while towing a boat (not overloaded or a heaving boat).
Scenario #1 cruising a road at 55 mph in 4th gear (4 speed auto). Cruise control goes to accelarate and all of a sudden a high speed shudder/vibration is felt throughout the entire vehicle.
Scenario #2 on the interstate driving 75 mph go to accelarate to compensate for a hill and the same high speed shudder/vibratio nis felt throughout the entire vehicle.
It is NOT alighnement or wheel balancing issue. Each time I pulled over, stopped the engine, got out checked everything with nothing found. Got back in restarted and finished my trip with no issues.
I am stearing towards, drive shaft out of balance, u-joint about to fail, transmission sticking or engine bearing.
What are your thoughts?
2008 Jeep Grand Cherokee Loredo 3.7L
eneusiis is offline
post #2 of 6 Old 09-15-2014, 10:24 AM
keggles
keggles's Avatar
2008 WK
It could also be engine mount or tranny mounts especially with it being under load and that speed.
I'm a nut, but not just a nut.
08 WK 5.7 Hemi 4x4
06 WK 4.7 - RIP
Silver WK Club #63
keggles is offline
post #3 of 6 Old 09-15-2014, 07:36 PM
ksteve
2009 WK
I was noticing a shudder for a short period of time while trailering a small boat. Usually while coasting. A week later, all hell broke loose and now my Jeep keeps slipping into neutral. Ive been trying to fix this issue for a while now. Still working on it.
ksteve is offline
post #4 of 6 Old 09-15-2014, 09:58 PM
ksteve
2009 WK
My transmission is mercedes, probably not related to what i am experiencing at all
ksteve is offline
post #5 of 6 Old 09-16-2014, 04:18 AM Thread Starter
eneusiis
2008 WK
Mine is a Mercedes tranny too I mistyped above 4 speed but it is the 5 speed Mercedes
eneusiis is offline
post #6 of 6 Old 09-16-2014, 01:01 PM
ksteve
2009 WK
K well i started a thread about my issues yesterday. I have already checked fluid level, not the problem. I checked the round plug on the side of the tranny which is for the harness that goes to the TCM. Thats known to leak fluid onto the wires and connections and cause all sorts of problems. That was not my issue. So I went ahead and did research on that Mercedes transmission. It is a Mercedes 722.6 Tranny. It is infamous for the failure of the Conductor Plate. It is a plastic plate mounted above the valve body which has copper leads coming from the plug (TCM Harness) and spits these leads to the solenoids and various sensors which are all a part of this plate. I found it on Amazon for $130. My local dealer in Canada quoted me $574 for the same Mercedes OEM part. I recently changed that and all the shuddering and falling out of gear problems were fix. Or so I thought, right now I am waiting until I can take it to the dealer to have the TCM DTC codes cleared and then a Transmission Adaption to be preformed. I'll get back to ya on that.
ksteve is offline
